Need help with Site to Site VPN
Kevin Cummins
Hello.
I inherited this router and I am trying to setup a vpn tunnel on a virtual interface. (I dont want to apply it directly to the outside interface)
This is my first time to do this, so I am pretty sure I am doing the setup wrong. The other side of the tunnel will be setup by someone else, I just need to make sure my side is set correctly. Below is what I have so far for my "crypto map vyatta". Please let me know what I am doing wrong or what I am missing (ACLs, routes, etc)
Router#sh run
Building configuration...
Current configuration : 16761 bytes
! Last configuration change at 23:39:53 JST Thu May 16 2012 by
! NVRAM config last updated at 23:39:58 JST Thu May 16 2012 by
version 12.4
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
crypto isakmp key 12345 address 118.55.32.64
crypto isakmp keepalive 20 periodic
crypto ipsec transform-set vyattaset esp-aes esp-sha-hmac
crypto map vyatta 50 ipsec-isakmp
set peer 118.55.32.64
set transform-set vyattaset
set pfs group5
match address 101
interface FastEthernet0
  bandwidth 100000
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
ip virtual-reassembly max-reassemblies 64
load-interval 30
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
description Unused
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Virtual-Template101 type tunnel
ip unnumbered Dialer1
crypto map vyatta
interface Dialer1
  bandwidth 100000
ip address 223.159.226.82 255.255.255.248
ip access-group xxx in
ip access-group yyy out
no ip redirects
ip accounting output-packets
ip mtu 1454
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly max-fragments 64 max-reassemblies 512
encapsulation ppp
ip route-cache policy
ip tcp adjust-mss 1414
load-interval 30
dialer pool 1
no cdp enable
ppp chap refuse
ppp pap sent-username fake@mail.com password 7 11111111111111111111111111
router eigrp 300
redistribute static
network 10.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip route 10.0.0.0 255.0.0.0 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 10.130.10.30 2055
ip flow-top-talkers
top 20
sort-by bytes
no ip http server
no ip http secure-server
ip nat translation timeout 600
ip nat inside source route-map NAT-RM interface Dialer1 overload
ip access-list extended xxx
permit tcp host 223.159.226.84 any eq smtp
permit tcp host 223.159.226.83 any eq smtp
permit tcp host 223.159.226.82 any eq smtp
deny   tcp any any eq smtp
permit ip any any
ip access-list extended yyy
remark Deny spoofing of internal network
deny   ip 223.159.226.81 0.0.0.7 any log
remark Block reserved addresses
deny   ip 10.0.0.0 0.255.255.255 any log
deny   ip 172.16.0.0 0.15.255.255 any log
deny   ip 192.168.0.0 0.0.255.255 any log
remark Block bogus network (RFC3330 bogons)
deny   ip 0.0.0.0 0.255.255.255 any log
deny   ip 127.0.0.0 0.255.255.255 any log
deny   ip 169.254.0.0 0.0.255.255 any log
deny   ip 192.0.2.0 0.0.0.255 any log
deny   ip 198.18.0.0 0.1.255.255 any log
deny   ip 224.0.0.0 15.255.255.255 any log
deny   ip 240.0.0.0 15.255.255.255 any log
remark Deny traffic from bad host addresses, 0.x.x.x and 255.255.255.255
deny   ip host 0.0.0.0 any log
deny   ip host 255.255.255.255 any log
remark Deny traffic to subnet address and subnet broadcast address
deny   ip any 0.0.0.0 255.255.255.0 log
deny   ip any 0.0.0.255 255.255.255.0 log
remark Allow any established traffic
permit tcp any 219.106.249.72 0.0.0.7 established
remark Allow good ICMP, block bad ICMP
deny   icmp any any log fragments
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any ttl-exceeded
permit icmp any any port-unreachable
permit icmp any any administratively-prohibited
permit icmp any any host-unreachable
remark Deny and log all other traffic by protocol
deny   tcp any any log
deny   udp any any log
access-list 101 permit ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
access-list 101 permit ip 10.130.20.0 0.0.0.255 10.70.35.0 0.0.0.255
route-map NAT-RM permit 10
match ip address NAT-ACL
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
login authentication NO_AAA
line aux 0
line vty 0 3
exec-timeout 30 0
logging synchronous
login authentication LOCALAUTHEN
rotary 1
transport input ssh
line vty 4
access-class SSH_VTY_FILTER in
exec-timeout 30 0
logging synchronous
rotary 1
transport input ssh
process cpu threshold type interrupt rising 50 interval 60 falling 20 interval 60
ntp clock-period 17180521
end
28 Replies 28
Below are all the other interfaces on my internet facing router (and core switch).
Im guessing I will need to make the tunnel to point to 10.130.100.3 then? (Since the 10.130.10/0 subnet is configured from the core switch)?
Sorry, this is a bit confusing for me too.
CoreSW
interface Vlan10
description SERVER-LAN-10.130.10.0/24
ip address 10.130.10.10 255.255.255.0
ip pim dense-mode
ip policy route-map POLICY-ROUTE
interface Vlan20
description DATA-LAN-10.130.20.0/24
ip address 10.130.20.10 255.255.255.0
ip helper-address 10.130.10.20
ip helper-address 10.130.10.22
router eigrp 300
redistribute static route-map STATIC->EIGRP
passive-interface default
no passive-interface Vlan100
no passive-interface GigabitEthernet1/0/4
no passive-interface GigabitEthernet2/0/4
network 10.130.0.2 0.0.0.0
network 10.130.0.6 0.0.0.0
network 10.130.1.1 0.0.0.0
network 10.130.8.10 0.0.0.0
network 10.130.10.10 0.0.0.0
network 10.130.20.10 0.0.0.0
network 10.130.35.1 0.0.0.0
network 10.130.35.33 0.0.0.0
network 10.130.40.10 0.0.0.0
network 10.130.70.0 0.0.0.0
network 10.130.100.10 0.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.130.100.1 name DEFAULT-HSRP-GATEWAY
Internet Router
interface Tunnel500
description DMVPN Hub - Tokyo
bandwidth 100000
ip address 10.150.0.1 255.255.255.0
no ip redirects
ip mtu 1370
ip flow ingress
ip hello-interval eigrp 300 15
ip hold-time eigrp 300 45
no ip next-hop-self eigrp 300
ip nhrp authentication sgdmvpn
ip nhrp map multicast dynamic
ip nhrp map 10.150.0.10 222.229.218.113
ip nhrp map multicast 222.229.218.113
ip nhrp network-id 550
ip nhrp holdtime 600
ip route-cache same-interface
ip tcp adjust-mss 1330
no ip split-horizon eigrp 300
ip summary-address eigrp 300 10.130.0.0 255.255.0.0 5
load-interval 30
qos pre-classify
tunnel source Dialer1
tunnel mode gre multipoint
tunnel key 55000
tunnel path-mtu-discovery
tunnel protection ipsec profile DMVPN-IPSEC-PROFILE
interface Tunnel600
ip address 10.160.0.1 255.255.255.0
tunnel destination 119.27.35.97
interface Loopback0
ip address 10.130.1.1 255.255.255.255
bandwidth 100000
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no cdp enable
description Unused
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
description to sgtkycoresw01 G1/0/1
switchport access vlan 100
load-interval 30
interface FastEthernet3
description to sgtkycoresw01 G2/0/1
load-interval 30
interface FastEthernet4
description to sgtkyfw01 Fa0/0
switchport access vlan 101
load-interval 30
interface FastEthernet5
description Unused
load-interval 30
interface FastEthernet6
description Unused
load-interval 30
interface FastEthernet7
description Unused
load-interval 30
interface FastEthernet8
description Unused
load-interval 30
interface FastEthernet9
description Unused
load-interval 30
interface Virtual-Template100 type tunnel
tunnel mode ipsec ipv4
tunnel protection ipsec profile DYNAMIC-IPSEC-PROFILE
Hello Kevin
Can you please post your network topology and full config of Internet router and core switch?
Network Topology
Backup Internet ----> Secondary Router
     Main Internet ---->Router------->CoreSwitch
                               ASA for SSL VPN
Full router config:
router01#sh run
version 12.4
no service pad
hostname router01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
logging buffered 4096 notifications
logging rate-limit 10 except warnings
no logging console
no logging monitor
enable secret 5 222222
aaa new-model
aaa authentication login XAUTH group radius local
aaa authentication login LOCALAUTHEN local
aaa authentication login NO_AAA none
aaa authorization network LOCALAUTHOR local
aaa session-id common
resource policy
clock timezone JST 9
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name routerstates.com
ip name-server 212.7.33.44
ip name-server 211.7.32.123
ip ssh port 4022 rotary 1
ip ssh source-interface Loopback0
ip ssh version 2
login block-for 600 attempts 3 within 15
login quiet-mode access-class SSH_VTY_FILTER
login on-failure log
login on-success log
track 1 rtr 1 reachability
track 2 rtr 2 reachability
track 3 list boolean and
object 1
object 2
class-map match-any VOIP
match ip dscp ef
match ip dscp af41
class-map match-any P2P
match protocol bittorrent
match protocol gnutella
match protocol kazaa2
match protocol fasttrack
match protocol edonkey
class-map match-all EIGRP
match protocol eigrp
policy-map D1_SHAPE
class class-default
  shape average 61440000 614400
policy-map T500_OUTBOUND_POLICY
class VOIP
  priority 2048
class EIGRP
  bandwidth 5120
class class-default
  fair-queue
policy-map T500_SHAPE
class class-default
  shape average 30720000 307200
  service-policy T500_OUTBOUND_POLICY
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 25
encr aes
group 5
lifetime 28800
crypto isakmp key xxxxx address 225.85.11.21 no-xauth
crypto isakmp key xxxxx address 226.1.32.44 no-xauth
crypto isakmp key xxxxx address 222.52.215.7 no-xauth
crypto isakmp key xxxxx address 216.42.221.123 no-xauth
crypto isakmp key xxxxx address 204.126.221.36 no-xauth
crypto isakmp key xxxxx address 117.53.197.90 no-xauth
crypto isakmp client configuration group osk-RA-VPN
key yyyyyyy
dns 10.130.10.20 10.130.10.22
wins 10.130.10.20
domain routerstates.com
pool DD-REMOTE-VPN-POOL
acl VPN-SPLIT-TUNNELS
crypto isakmp profile VTI-ISAKMP-PROFILE
   match identity group OSK-RA-VPN
   client authentication list XAUTH
   isakmp authorization list LOCALAUTHOR
   client configuration address respond
   virtual-template 100
crypto ipsec transform-set DYNAMIC-TSET esp-aes esp-md5-hmac
crypto ipsec transform-set DMVPN-TSET esp-aes esp-md5-hmac
mode transport
crypto ipsec profile DMVPN-IPSEC-PROFILE
set transform-set DMVPN-TSET
set pfs group2
crypto ipsec profile DYNAMIC-IPSEC-PROFILE
set transform-set DYNAMIC-TSET
set pfs group5
interface Tunnel500
bandwidth 100000
no ip redirects
ip mtu 1370
ip flow ingress
ip nhrp authentication dddmvpn
ip nhrp map 10.150.0.10 212.168.25.63
ip nhrp map multicast 212.168.25.63
load-interval 30
qos pre-classify
tunnel key 55000
interface Loopback0
bandwidth 100000
no ip address
no ip redirects
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no cdp enable
description Unused
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
description to ddoskcoresw01 G1/0/1
load-interval 30
description to ddoskcoresw01 G2/0/1
load-interval 30
description to ddoskfw01 Fa0/0
load-interval 30
description Unused
load-interval 30
description Unused
load-interval 30
description Unused
load-interval 30
description Unused
load-interval 30
description Unused
load-interval 30
interface Vlan1
description Unused
no ip address
shutdown
interface Vlan100
description to Core (10.130.100.0/24)
ip address 10.130.100.3 255.255.255.0
no ip redirects
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
standby 2 ip 10.130.100.1
standby 2 priority 110
standby 2 preempt delay minimum 60
standby 2 track 3 decrement 20
interface Vlan101
description WAN GW to FW VLAN
bandwidth 100000
ip address 10.130.0.9 255.255.255.252
no ip redirects
ip flow ingress
ip nat inside
load-interval 30
interface Dialer1
bandwidth 100000
ip access-group INGRESS_FILTER in
ip access-group EGRESS_FILTER out
no ip redirects
ip mtu 1454
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
ppp chap refuse
ppp pap sent-username fake@email.com password 7 yyyyyyy
router eigrp 300
redistribute static
network 10.0.0.0
no auto-summary
ip local policy route-map IPSLA-TO-OCN
ip local pool dd-REMOTE-VPN-POOL 10.130.202.1 10.130.202.50
ip flow-top-talkers
top 20
sort-by bytes
no ip http server
ip nat inside source static tcp 10.130.10.30 21 223.159.226.82 21 extendable
ip nat inside source static tcp 10.130.10.54 25 223.159.226.82 25 extendable
ip nat inside source static tcp 10.130.0.10 443 223.159.226.82 443 extendable
ip nat inside source static tcp 10.130.10.42 3101 223.159.226.82 3101 extendable
ip nat inside source static tcp 10.130.10.29 4001 223.159.226.82 4001 extendable
ip nat inside source static tcp 10.130.10.27 80 223.159.226.82 5000 extendable
ip nat inside source static tcp 10.130.10.27 443 223.159.226.82 5001 extendable
ip nat inside source static 10.130.0.10 223.159.226.88
ip nat inside source static 10.130.10.20 223.159.226.83
ip nat inside source static 10.130.10.24 223.159.226.85
ip nat inside source static 10.130.10.23 223.159.226.86
ip nat inside source static tcp 10.130.10.55 25 223.159.226.87 25 extendable
ip nat inside source static tcp 10.130.10.54 443 223.159.226.87 443 extendable
ip access-list standard SNMP_FILTER
remark Allow SNMP access from oskpmon01
permit 10.130.10.30
deny   any log
ip access-list standard SSH_VTY_FILTER
remark Permit ddoskwan01
permit 223.159.226.82
remark Permit oskwan02
permit 226.1.32.44
remark Permit oskwan01
permit 225.85.11.21
remark Permit ddhkwan01
permit 204.126.221.36
remark Permit ddoskwan02
permit 222.52.215.7
remark Permit Internal networks
permit 10.130.0.0 0.0.255.255
permit 10.131.0.0 0.0.255.255
permit 10.132.0.0 0.0.255.255
deny   any log
ip access-list extended EGRESS_FILTER
permit tcp host 223.159.226.87 any eq smtp
permit ip any any
ip access-list extended INGRESS_FILTER
deny   ip 223.159.226.79 0.0.0.7 any log
permit tcp any 223.159.226.79 0.0.0.7 established
remark Allow SSH to router on non-default port 4022
permit tcp any host 223.159.226.82 eq 4022
remark Allow services to ddvmmoss01
permit tcp any host 223.159.226.82 eq 443
permit tcp any host 223.159.226.82 eq smtp
permit tcp any host 223.159.226.82 eq 5000
permit tcp any host 223.159.226.82 eq 5001
remark Allow services to systemddo08
permit tcp any host 223.159.226.83 eq smtp
permit tcp any host 223.159.226.83 eq www
permit tcp any host 223.159.226.83 eq 443
permit tcp any host 223.159.226.83 eq pop3
permit tcp any host 223.159.226.83 eq 143
permit tcp any host 223.159.226.83 eq 993
permit tcp any host 223.159.226.83 eq 995
permit udp any host 223.159.226.83 eq ntp
permit udp any gt 1023 host 223.159.226.83 eq domain
permit udp any eq domain host 223.159.226.83 gt 1023
remark Allow services to ddsql01
permit udp any gt 1023 host 223.159.226.85 eq domain
permit udp any eq domain host 223.159.226.85 gt 1023
permit tcp any gt 1023 host 223.159.226.85 eq domain
permit tcp any eq domain host 223.159.226.85 eq domain
permit tcp any host 223.159.226.85 eq www
permit tcp any host 223.159.226.85 eq 443
permit tcp any host 223.159.226.85 eq ftp
remark Allow services to ddweb01
permit tcp any host 223.159.226.86 eq 443
permit tcp any host 223.159.226.86 eq www
remark Allow services to oskp-ex02
permit tcp any host 223.159.226.87 eq 443
remark Allow services to oskp-ex08
permit tcp any host 223.159.226.87 eq smtp
remark Allow services to ddfp02 (no NAT IP available)
permit udp any gt 1023 any eq domain
permit udp any eq domain any gt 1023
remark Allow IPSEC from remote offices
permit esp host 226.1.32.44 host 223.159.226.82
permit esp host 225.85.11.21 host 223.159.226.82
permit esp host 222.52.215.7 host 223.159.226.82
permit esp host 204.126.221.36 host 223.159.226.82
permit esp host 117.53.197.90 host 223.159.226.82
remark Allow GRE tunnels from remote offices and from Internet for returning PPTP packets
permit gre any host 223.159.226.82
remark Allow ISAKMP from remote offices
permit udp host 226.1.32.44 host 223.159.226.82 eq isakmp
permit udp host 225.85.11.21 host 223.159.226.82 eq isakmp
permit udp host 222.52.215.7 host 223.159.226.82 eq isakmp
permit udp host 204.126.221.36 host 223.159.226.82 eq isakmp
permit udp host 117.53.197.90 host 223.159.226.82 eq isakmp
remark Allow ISAKMP for ddoskfw01 IPSEC VPN clients
permit udp any host 223.159.226.88 eq isakmp
permit udp any host 223.159.226.88 eq non500-isakmp
permit udp any eq non500-isakmp host 223.159.226.88
remark Allow ISAKMP for ddoskwan01 IPSEC VPN client and also returning IPSEC packets from internal clies
permit udp any eq isakmp host 223.159.226.82
permit udp any host 223.159.226.82 eq non500-isakmp
permit udp any eq non500-isakmp host 223.159.226.82
remark Permit Netmon MSP
permit tcp any host 223.159.226.82 eq 4001
remark Allow registered bittorrent traffic
permit tcp any gt 1023 host 223.159.226.82 range 16114 16116
permit udp any gt 1023 host 223.159.226.82 range 16114 16116
ip access-list extended IPSLA-TO-OCN
permit icmp any host 211.9.33.76
permit icmp any host 211.9.32.235
ip access-list extended NAT-ACL
remark deny static NAT entries
deny   ip host 10.130.0.10 any
deny   ip host 10.130.10.20 any
deny   ip host 10.130.10.23 any
deny   ip host 10.130.10.24 any
remark permit dd
permit ip 10.130.0.0 0.0.255.255 any
ip access-list extended P2P
deny   ip host 10.130.20.82 any
deny   ip host 10.130.20.153 any
deny   ip any host 10.130.20.153
permit ip any any
ip access-list extended P2p
ip access-list extended VPN-SPLIT-TUNNELS
remark ACL for VPN client split tunnel networks
permit ip 10.131.0.0 0.0.255.255 any
permit ip 10.132.0.0 0.0.255.255 any
permit ip 10.2.1.0 0.0.0.255 any
permit ip 10.137.0.0 0.0.255.255 any
permit ip 10.133.0.0 0.0.255.255 any
ip radius source-interface Loopback0
ip sla 1
icmp-echo 211.9.33.76
timeout 1000
threshold 30
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 211.9.32.235
timeout 1000
threshold 30
frequency 10
ip sla schedule 2 life forever start-time now
ip access-list logging interval 100
logging trap debugging
logging source-interface Loopback0
logging 10.130.10.29
logging 10.130.10.30
snmp-server community ddxOP1 RO SNMP_FILTER
snmp-server ifindex persist
snmp-server enable traps cpu threshold
snmp-server host 10.130.10.29 ddxOP1  cpu
route-map IPSLA-TO-OCN permit 10
match ip address IPSLA-TO-OCN
set interface Dialer1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.130.10.22 auth-port 1645 acct-port 1646
radius-server host 10.130.10.20 auth-port 1645 acct-port 1646
radius-server key 7 yyyyyyyyyy
control-plane
banner login ^C
WARNING: Unauthorized access to this system is forbidden and will be
prosecuted by law. By accessing this system, you agree that your
actions may be monitored if unauthorized usage is suspected.
^C
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
line vty 0 3
exec-timeout 30 0
logging synchronous
rotary 1
transport input ssh
line vty 4
exec-timeout 30 0
logging synchronous
rotary 1
transport input ssh
ntp clock-period 17180446
ntp server 10.130.10.20
end
router01#
deny ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
deny ip 10.130.20.0 0.0.0.255 10.70.35.0 0.0.0.255
remark permit dd
permit ip any any
Try and let me know the status.
Still didnt work.
I tried traceroute from a PC in the 10.130.10.0/24 subnet, but its getting stopped at 10.130.100.3 with a Destination Unreachable message.
Hello Kevin
There is one command missing in the Crypto map as highlighted below and subsequent access-list
set pfs group5
match address 150
access-list 150 permit ip 10.130.10.0 0.0.0.255 10.70.35.0 0.0.0.255
access-list 150 permit ip 10.130.20.0 0.0.0.255 10.70.35.0 0.0.0.255
If still doesn't work, Please run the debug crypto isakmp & debug crypto ipsec and post the output.
Cheers
Chandrakant
Debug IPSEC
router01#
510426: May 24 12:27:28.929: IPSEC(key_engine): got a queue event with 1 KMI message(s)
510427: May 24 12:27:28.929: Delete IPsec SA by DPD, local 223.159.226.82 remote 118.55.32.64 peer port 500
510428: May 24 12:27:28.929: IPSEC(delete_sa): deleting SA,
  (sa) sa_dest= 223.159.226.82, sa_proto= 50,
    sa_spi= 0xD4734153(3564323155),
    sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 181,
  (identity) local= 223.159.226.82, remote= 118.55.32.64,
    local_proxy= 10.130.10.0/255.255.255.0/0/0 (type=4),
    remote_proxy= 10.70.35.0/255.255.255.0/0/0 (type=4)
router01#
510429: May 24 12:27:28.929: IPSEC(update_current_outbound_sa): updated peer 118.55.32.64 current outbound sa to SPI 0
510430: May 24 12:27:28.929: IPSEC(delete_sa): deleting SA,
  (sa) sa_dest= 118.55.32.64, sa_proto= 50,
    sa_spi= 0x31FB12E(52408622),
    sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 182,
510431: May 24 12:27:28.929: IPSEC(key_engine): got a queue event with 1 KMI message(s)
router01#
510432: May 24 12:27:39.509: IPSEC(validate_proposal_request): proposal part #1
510433: May 24 12:27:39.509: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= 223.159.226.82, remote= 118.55.32.64,
    remote_proxy= 10.70.35.0/255.255.255.0/0/0 (type=4),
    protocol= ESP, transform= esp-3des esp-md5-hmac  (Tunnel),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
510434: May 24 12:27:39.509: map_db_find_best did not find matching map
510435: May 24 12:27:39.509: Crypto mapdb : proxy_match
        src addr     : 10.130.10.0
        dst addr     : 10.70.35.0
        protocol     : 0
        src port     : 0
        dst port     : 0
510436: May 24 12:27:39.581: IPSEC(key_engine): got a queue event with 1 KMI message(s)
510437: May 24 12:27:39.581: map_db_find_best did not find matching map
510438: May 24 12:27:39.581: Crypto mapdb : proxy_match
        dst ad
router01#dr     : 10.70.35.0
        protocol     : 0
        src port     : 0
        dst port     : 0
510439: May 24 12:27:39.581: IPSEC(crypto_ipsec_sa_find_ident_head): reconnecting with the same proxies and peer 118.55.32.64
510440: May 24 12:27:39.581: IPSEC(policy_db_add_ident): src 10.130.10.0, dest 10.70.35.0, dest_port 0
510441: May 24 12:27:39.581: IPSEC(create_sa): sa created,
    sa_spi= 0xCA9BF70C(3399218956),
    sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 183
510442: May 24 12:27:39.581: IPSEC(create_sa): sa created,
    sa_spi= 0xD478BEAD(3564682925),
    sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 184
510443: May 24 12:27:39.681: IPSEC(key_engine): got a queue event with 1 KMI message(s)
510444: May 24 12:27:39.681: IPSEC(key_engine_enable_outbound): rec'd enable notify from ISAKMP
510445: May 24 12:27:39.681: IPSEC(key_engine_enable_outbound): enable SA with spi 3564682925/50
510446: May 24 12:27:39.681: IPSEC(update_current_outbound_sa): updated peer 118.55.32.64current outbound sa to SPI D478BEAD
router01#
Debug ISAKMP
510025: May 24 12:24:03.490: ISAKMP (0:2111): received packet from 118.55.32.64 dport 500 sport 500 Global (R) QM_IDLE
510026: May 24 12:24:03.490: ISAKMP: set new node 178916013 to QM_IDLE
510027: May 24 12:24:03.490: ISAKMP:(2111): processing HASH payload. message ID = 178916013
510028: May 24 12:24:03.490: ISAKMP:(2111): processing NOTIFY DPD/R_U_THERE_ACK protocol 1
        spi 0, message ID = 178916013, sa = 848A3554
510029: May 24 12:24:03.490: ISAKMP:(2111): DPD/R_U_THERE_ACK received from peer
118.55.32.64, sequence 0x284C1013
510030: May 24 12:24:03.490: ISAKMP:(2111):deleting node 178916013 error FALSE reason "Informational (in) state 1"
510031: May 24 12:24:03.490: ISAKMP:(2111):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
510032: May 24 12:24:03.490: ISAKMP:(2111):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
Also tried changing Encryption on both ends to 3des/md5, still no go.
Message was edited by: Kevin Cummins
Kevin,
If you look at your prev outputof sh ipsec sa peer . you can see that the packets encrypted/decrypted  are "0". meaning that the traffic from the 10.130. is not hitting the tunnel.  Can you do a trace from core sw sourcing vlan 20?
We need to see where the traffic is dropping before it hits the ipsec tunnel. Your tunnel established fine its just that the data doesnt get through it right?
Kishore
Yeah, it looks like the tunnel is up, and it says the status is Active, but can ping to/from either side.
coresw01#traceroute
Protocol [ip]:
Target IP address: 10.70.35.10
Source address: 10.130.10.10
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to 10.70.35.10
  1 10.130.100.2 0 msec
    10.130.100.3 0 msec
    10.130.100.2 0 msec
  2  *  *  *
  3  *
    10.130.100.3 !H  *
coresw01#traceroute
Protocol [ip]:
Source address: 10.130.20.10
Probe count [3]:
  1 10.130.100.3 0 msec
    10.130.100.2 0 msec
    10.130.100.3 0 msec
  2  *  !H  *
sgtkycoresw01#
can you do a  "sh ip route 10.70.35.10" on the internet router and also the core sw as well please.
router01#sh ip route 10.70.35.10
Routing entry for 10.0.0.0/8
  Known via "static", distance 1, metric 0 (connected)
  Redistributing via eigrp 300
  Advertised by eigrp 300
  Routing Descriptor Blocks:
  * directly connected, via Null0
      Route metric is 0, traffic share count is 1
Here's coresw:
coresw01#sh ip route 10.70.35.10
  Known via "eigrp 300", distance 90, metric 2816, type internal
  Last update from 10.130.100.3 on Vlan100, 7w0d ago
  * 10.130.100.3, from 10.130.100.3, 7w0d ago, via Vlan100
      Route metric is 2816, traffic share count is 1
      Total delay is 10 microseconds, minimum bandwidth is 1000000 Kbit
      Reliability 255/255, minimum MTU 1500 bytes
      Loading 1/255, Hops 1
    10.130.100.2, from 10.130.100.2, 7w0d ago, via Vlan100
Hello Kevin
If you see the debug output, it is failing at Phase 2 - IPsec Negotitation.
router01#
protocol : 0
src port : 0
dst port : 0
dst ad
protocol : 0
src port : 0
dst port : 0
You need to check the IPSec SA at both ends and also check the access-list. The crypto access-lists has to be identical at both ends.
Cheers
Chandrakant
router01#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES NVRAM  up                    up
FastEthernet1              unassigned      YES NVRAM  administratively down down
BRI0                       unassigned      YES NVRAM  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  up                    up
FastEthernet4              unassigned      YES unset  up                    up
FastEthernet5              unassigned      YES unset  up                    down
FastEthernet6              unassigned      YES unset  up                    down
FastEthernet7              unassigned      YES unset  up                    down
FastEthernet8              unassigned      YES unset  up                    down
FastEthernet9              unassigned      YES unset  up                    down
Vlan1                      unassigned      YES NVRAM  administratively down down
Loopback0                  10.130.1.1      YES NVRAM  up                    up
Tunnel500                  10.150.0.1      YES NVRAM  up                    up
Dialer1                    223.159.226.8  YES NVRAM  up                    up
Virtual-Template100   223.159.226.8 YES TFTP   down                  down
Vlan100                    10.130.100.3    YES NVRAM  up                    up
NVI0                       unassigned      NO  unset  up                    up
Vlan101                    10.130.0.9      YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  down                  down
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Virtual-Template101     223.159.226.8  YES TFTP   down                  down
Tunnel600                  10.160.0.1      YES manual up                    up
router01#
your virtual interface is showing as down/down. umm if you are going to use ipsec profiles etc then i believe you dont need to add any cryptomap etc. Not sure why your ipsec debugs are showing cannot find a matching map
Please how the VTI is configured. Maybe this will help.
http://www.cisco.com/en/US/technologies/tk583/tk372/technologies_white_paper0900aecd8029d629.html
