Need recommendation on 3825
I'm building a lab at work and I'm hoping to score 2x 3825. However, I'd like at least one of them to have the cards necessary so I could replace a production 3725 incase I need to.
The 3725 is running:
(C3725-ADVIPSERVICESK9-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
and has the following interfaces:
Cisco 3725 (R7000) processor (revision 0.1) with 196608K/65536K bytes of memory.
Processor board ID JMX0727L060
R7000 CPU at 240MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
2 FastEthernet interfaces
1 Serial interface
1 HSSI interface
2 Channelized T1/PRI ports
DRAM configuration is 64 bits wide with parity disabled.
55K bytes of NVRAM.
62592K bytes of ATA System CompactFlash (Read/Write)
62720K bytes of ATA Slot0 CompactFlash (Read/Write)
What cards and license would I need for the 3825 to replace this?
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Need recommendation on 3825
Hi, a wic-1t, nm-hssi or t3, and vwic or vwic2 will do.
Hope this helps, if please rate post!
1 REPLY
101
