Webcast-Catalyst9k
Need some information regarding PRI??
Hi frnds,
I just want to know that VWIC2-1MFT-T1/E1 supported PRI or not??
Appreciate ur help....
1 ACCEPTED SOLUTION
Re: Need some information regarding PRI??
Yes it would
Narayan
Yes it would
Narayan
Hi Narayan,
Thanx for ur help.Really appreciates your efforts. One thing i want to know that this card supported PRI only for voice calls or can support both voice & data Calls?
It supports both data and voice transmission but when you configure it for PRI, you cannot use it for Data
For data you would ocnfigure it as
Channel-groups and for PRI(voice) you need to configure it as pri-group
Narayan
113
