12-07-2011 12:00 AM - edited 03-04-2019 02:32 PM
Hi All,
I want to reserve b/w for my IP Phones . please let me know the configuration for b/w revervation on router. my current config is as :
class-map match-any VOICE-RTP
match access-group 100
class-map match-any VOICE-Control
match access-group 101
policy-map QoS-Policy
class VOICE-RTP
class VOICE-Control
class class-default
fair-queue
access-list 100 permit ip any any precedence critical
access-list 100 permit ip any any dscp ef
access-list 101 permit tcp any any range 2000 2002
access-list 101 permit tcp any any range 11000 11999
i have created a seprate VLAN for IPT.
with Thanks & Regards,
Manmohan
Solved! Go to Solution.
12-09-2011 02:39 PM
Your almost there. In your class maps, add the bandwidth command. It would look something like this. Of course, you need to do the math on how much bandwidth you want reserved for each class.
bandwidth 1000 <<-------- This is saying that the pipe the traffic is going through is a 1M (1,000K) pipe
So, based on your post, if you wanted to make sure each phone got 95k which to me means you are using G711 (64k plus some overhead) and accounted for both streams (two way conversation remember), you would need a total of 190k per phone. So, 1000k divided by 190 = 5 phones with a little bit of room. Remember, the bandwidth command doesn't choke down the traffic across the pipe. It just makes sure that at least 1000k of bandwidth (if available from the service provider) is alloted to the class-map you assign it to. It is very easy to create complex class-maps that oversubscribe the WAN pipe and you end up with little to no QOS over voice traffic. Hope this helps.
12-09-2011 02:39 PM
01-07-2019 12:23 AM
