06-16-2006 04:24 AM - edited 03-03-2019 01:01 PM
This machine is giving me hard time. The problem with it is that it keeps on rebooting. I have tried to even load another IOS. But it is not working out. It is bringing this output......========= Dump bp = 2C66478 ======================
2C66378: 0 0 0 0 0 0 0
2C66398: 0 0 0 0 0 0 0
2C663B8: 0 0 0 0 0 0 0
2C663D8: 0 0 0 0 0 0 0
2C663F8: 0 0 0 0 0 0 0 FD0110D
F
2C66418: AB1234CD FFFFFFFE 0 0 800261A4 2C66478 2C183EC 8000001
C
2C66438: 1 175C7D59 70600180 DCBE0B00 C164 0 100 2C664A
2C66458: 2C668E0 0 0 0 0 0 0 FD0110D
F
2C66478: AB1234CD FFFFFFFE 0 0 800261C8 2C668B8 2C6642C 8000020
C
2C66498: 1 A35C1E12 15A 8000F9F4 2C67160 0 15A 8000F9F
2C664B8: 2C677E0 0 15A 8000F9F4 2C67E60 0 15A 8000F9F
2C664D8: 2C684E0 0 40 8000F9F4 2C68B60 0 40 8000F9F
2C664F8: 2C691E0 0 0 8000F9F4 2B657E0 0 0 8000F9F
2C66518: 2B65160 0 0 8000F9F4 2B64AE0 0 0 8000F9F
2C66538: 2B64460 0 0 8000F9F4 2B63DE0 0 0 8000F9F
2C66558: 2B63760 0 0 8000F9F4 2B630E0 0 0 8000F9F
========= Dump bp->next = 2C668B8 ======================
2C667B8: 2B73E20 0 0 8000F9F4 2B737A0 0 0 8000F9F
2C667D8: 2B73120 0 0 8000F9F4 2B72AA0 0 0 8000F9F
2C667F8: 2B72420 0 0 8000F9F4 2B71DA0 0 0 8000F9F
2C66818: 2B71720 0 0 8000F9F4 2B710A0 0 0 8000F9F
2C66838: 2B70A20 0 0 8000F9F4 2B703A0 0 0 8000F9F
2C66858: 2B6FD20 0 0 8000F9F4 2B6F6A0 0 0 8000F9F
2C66878: 2B6F020 0 0 8000F9F4 2B6E9A0 0 0 8000F9F
2C66898: 2B6E320 0 0 0 0 0 0 FD0110D
F
2C668B8: AB1234CD FFFFFFFE 0 3000000 80026214 2C670F8 0 300040
C
2C668D8: 1 8DB14C70 0 8300FECE 2B050C2 0 0 8300FEC
E
2C668F8: 2B057A2 0 0 300FECE 2B05E82 0 0 300FFC
2C66918: 2B01D8A 0 0 8300FFC4 2B01ECA 0 0 8300FEC
9
2C66938: 2CD38C2 0 0 300FFC4 2CCF22A 0 0 300FFC
2C66958: 2CCF4AA 0 0 8300FFC4 2CCF72A 0 0 8300FFC
2C66978: 2CCF9AA 0 0 0 0 0 0
2C66998: 0 0 0 0 0 0 0
========== Dump bp->previous = 2C6642C =====================
2C6632C: 0 0 0 0 0 0 0
2C6634C: 0 0 0 0 0 0 0
2C6636C: 0 0 0 0 0 0 0
2C6638C: 0 0 0 0 0 0 0
2C663AC: 0 0 0 0 0 0 0
2C663CC: 0 0 0 0 0 0 0
2C663EC: 0 0 0 0 0 0 0
Then it says (Software forced reload.) Pliz help.
06-16-2006 05:53 AM
If you can troubleshoot the device without it rebooting then take a look at the memory. Do a show process memory and see if it has enough memory to function. If memory is not the issue then look at the logs of the router to see if anything is showing up. If still stuck then open a TAC case with Cisco , possibly the router is bad and you need a new unit....Good Luck..Please rate...
06-16-2006 06:39 AM
What is the history of this router? Did you recently make changes, like a new IOS, for example? That software forced reload error makes me wonder if you do not have enough DRAM to run the IOS currently loaded in it. I know you said you tried different software, but wondering if you reloaded software several times and the latest ones require more DRAM than is in the router.
06-16-2006 10:30 AM
Is the router a 2600XM or just a 2600? And what about the IOS is that the 2600XM or the 2600?
As the other two stated, try and downgrade to an IP only IOS and see if that works.
06-17-2006 01:35 AM
I just downloaded a new IOS which is almost the same as the IOS that was running in the router. I did this because I thought that the current IOS was somehow corrupt. And this is the fist time I am loading any other software on it, Some one again told me about something to do about DRAM. But I dont think there should be anything.
06-16-2006 11:46 AM
same problem i also had faced...some people told this is the problem of hardware...but you should contact TAC...
regards
Devang
06-17-2006 04:03 AM
(1)Is this output comming after completion of booting process or initially?(If possible pls port the complete boot process output)
(2)(This step is not recommended for novoices...you may end up in trouble.)Try removing the flash and see the router goes into ROMMON?
(3)Are you able to enable break-sequence(CTRL-Break) and the router boots to ROMMON?Then try bypassing the config. and see what happens?
JD
06-18-2006 08:10 PM
mark what was the pre-software and to what you upgraded. try to check memory error. some times bootstart programes gives error.
