04-17-2008 04:51 PM - edited 03-03-2019 09:36 PM
I am trying to enable net flow on interface of 6500 series switch ,I am using Sup720 3BXL. version SXH. For some reason the command "ip route-cache flow" not supported . Can any one know the correct command ?
04-17-2008 05:21 PM
what version of sxh do you have?
Cisco IOS Release 12.2(33)SXH and later releases support per-interface NDE, which enables PFC NetFlow data collection on a per-interface basis. With releases earlier than Release 12.2(33)SXH, NetFlow on the PFC could be only be enabled and disabled globally.
Good Doc:
You may just need to upgrade!
04-17-2008 05:59 PM
Thanks for the reply. I have Cisco 12.2(33) SXH.Still for some reason i couldn't able to do it. Can you help me in fixing the problem? when i tab ip on interface mode, it suppose to print "route"- and next cache..
Kiran
04-17-2008 06:09 PM
Use the command "ip flow ingress" on the interface you want to configure netflow on.
04-17-2008 06:21 PM
Here is the info :
Cisco#conf t
Enter configuration commands, one per line. End with CNTL/Z.
cisco(config)#int gi3/1
Cisco(config-if)#ip flow ingress
% Invalid input detected at '^' marker.
Cisco(config-if)#ip ?
Interface IP configuration subcommands:
access-group Specify access control for packets
admission Apply Network Admission Control
arp Configure ARP features
auth-proxy Apply authenticaton proxy
dhcp Configure DHCP parameters for this interface
dhcp DHCP
header-compression IPHC options
igmp IGMP interface commands
rsvp RSVP interface commands
rtp RTP parameters
verify verify
vrf VPN Routing/Forwarding parameters on the interface
Cisco(config-if)#ip
