Community Member
net flow
hello
i configured on my cisco 1841 net flow
can i change the interval from the minimum 1 minute to few seconeds ?
ip flow-cache timeout active 1
thanks
1 REPLY
Hall of Fame Super Silver
Re: net flow
Hello Golan,
according to Neflow command reference
http://www.cisco.com/en/US/docs/ios/netflow/command/reference/nf_01.html#wp1013625
active
Specifies the active flow timeout.
minutes
(Optional) The number of minutes that an active flow remains in the cache before it times out. The range is from 1 to 60. The default value is 30.
you cannot specify a time less then 1 minute.
However, I wonder if this makes sense the flow cache needs to store active flow for some time. Of course the table has a limited size and to avoid overflow it can be wise to reduce the time an active flow uses one entry in the cache but the lower limit is 1 minute.
Hope to help
Giuseppe
363
