02-24-2014 06:04 AM - edited 03-04-2019 10:25 PM
We are looking at possibly using Netflow to monitor internet usage on sites.
As I have never used Netflow before, does anyone have the basic config that I can use on a router like a 887 and any details on the server end, like software etc that would be easy enough for someone to connect to, to see internet traffic usage.
Solved! Go to Solution.
02-25-2014 07:13 AM
I believe your device supports NetFlow v5. Here is a sample configuration:
The following is a set of commands issued on a Cisco router to enable NetFlow version 5 on the FastEthernet 0/1 interface and export to the machine 192.168.9.101 (IP Address of NetFlow Analyzer server) on port 9996 (UDP port to export NetFlow packets).
router#enable
Password:*****
router#configure terminal
887(config)#interface FastEthernet 0/1
887(config-if)#ip route-cache flow // Execute this command on all the L3/VLAN interfaces
887(config-if)#exit
887(config)#ip flow-export destination 192.168.9.101 2055 // Use IP address of the NetFlow Analyzer server
887(config)#ip flow-export source loopback0 // Use an interface with route to your NetFlow server
887(config)#ip flow-export version 5
887(config)#ip flow-cache timeout active 1
887(config)#ip flow-cache timeout inactive 15
887(config)#snmp-server ifindex persist
887(config)#^Z
router#write
And if you need a video:
http://www.youtube.com/watch?v=KujLCfW2V8w
For NetFlow monitoring check out trial/free options from SolarWinds, ManageEngine or Plixer. All three are good. And here is the link to SolarWinds free tool:
http://www.solarwinds.com/products/freetools/real-time-bandwidth-monitor.aspx
Don Jacob
Disclaimer: I work for SolarWinds
NOTE: Please rate and close questions if you found any of the answers helpful.
02-25-2014 07:13 AM
router#enable
Password:*****
887(config-if)#exit
887(config)#^Z
router#write
Don Jacob
