Webcast-Catalyst9k
NetFlow exports on 4500s
I have NetFlow configured on 2 different 4500s, with the below hardware:
THATCH_CR451_01#sh mod
Chassis Type : WS-C4510R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model
1 2 Supervisor V 1000BaseX (GBIC) WS-X4516
Mod Submodule Model
1 Netflow Services Card WS-F4531
running IOS: cat4500-entservices-mz.122-25.SG4.bin
THATCH_CR451_01#sh ip flow export
Flow export v5 is enabled for main cache
Exporting flows to 161.12.20.11 (9991)
Exporting using source interface Loopback0
Version 5 flow records
47178983 flows exported in 1572650 udp datagrams
and....
HORLEY_CC450_01#sh mod
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
1 2 Supervisor IV 1000BaseX (GBIC) WS-X4515
Mod Submodule Model
running IOS: cat4500-entservices-mz.122-25.SG.bin
HORLEY_CC450_01#sh ip flow export
2137814974 flows exported in 71260500 udp datagrams
both have the same config applied:
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 161.12.20.11 9991
There is no option to add the "ip route-cache" line under each layer-3 interface, however HORLEY_CC450_01 is collecting stats, but the THATCH_CC450_01 is not....
Feature navigator states netflow should work on the IOS installed, but is defintely not. I can see flows saying they are being exported, but not collecting within Netflow. Is this a known bug, or is there additional config needed? Any help appreciated.
Phil
1 ACCEPTED SOLUTION
Re: NetFlow exports on 4500s
I found some documentation stating this as well, but I believe it is specific to routers.
I also found this document: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25ew/configuration/guide/nfswitch.html#wp1014923 which explicitly states "Enabling NetFlow on a per interface basis is not supported on a Catalyst 4500 switch."
Ahoy Phil,
Have you had any success with this? I am experiencing the same issue on cat4000-i5k91s-mz.122-25.EWA14.bin.
Would appreciate any insight, thanks!
-Adam
No - nothing of note to resolve this problem... I guess its a 'feature' with the cisco code/HW combination....
Rgds
Phil
in some recent IOS releases Cisco Express Forwarding has to be enabled. make sure you've issued the ip cef command in global config mode
If only it was that easy... CEF configured on all 4500s already....
Adam,
"ip flow ingress infer-fields" in global config command enabled netflow for me....
thanks for your help!... be warned though, when entering the command your session freezes for a short period, so be careful if adding on a live network in the middle of the day (just in case it does have an impact)!
198
