Netflow module on 4506
folks
i've installed a netflow card, WS-F4531, on one of my 4506 switches but i'm not getting the reports i expected
the card is installed ok and all the commands are correct (so i'm told)
i'm using 3rd party software from crannog software to report the exported results
my problem:
i was expecting the same results as i get from my routers, i.e. per interface details but with the switch all i'm getting is per vlan and as i only run a single vlan on this switch the results mean little
has anyone tried this themselves and resolved it?
many thanks to anyone taking the time to reply
Re: Netflow module on 4506
can i see the config. if its ok...........
asssuming the config is correct. i would suggest to get in touch with the crannog software, we had a problem similar to this its resolved by the company.
thanks for your reply
i've taken out alot of the config - irrelevant stuff mostly - thanks again
Current configuration : 20461 bytes
! Last configuration change at 12:20:37 UTC Fri Jan 6 2006 by ***********
! NVRAM config last updated at 12:11:27 UTC Fri Jan 6 2006 by ***********
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
service compress-config
hostname *******4506
boot system flash bootflash:cat4000-i9s-mz.121-19.EW1.bin
logging buffered informational
logging monitor notifications
aaa new-model
aaa authentication login default group tacacs+ local line
aaa authentication enable default group tacacs+ enable line
aaa accounting exec default start-stop group tacacs+
enable secret 5 ************************
vtp mode transparent
ip subnet-zero
ip flow-cache timeout active 1
ip domain-name ***.***.**
ip name-server 10.*.*.*
interface Vlan1
ip address 10.*.*.* 255.255.254.0
ip default-gateway 10.*.*.*
ip flow-export version 5
ip flow-export destination 10.*.*.* 2055
ip route-cache flow infer-fields
ip classless
ip route 0.0.0.0 0.0.0.0 10.*.*.*
ip http server
logging facility local6
logging 10.*.*.*
tacacs-server host 10.*.*.*
tacacs-server key ************
line con 0
exec-timeout 35791 0
password *********
stopbits 1
line vty 0 4
password *********
ntp clock-period 17179879
ntp server 10.*.*.*
monitor session 1 source vlan 1
monitor session 1 destination interface Fa4/34
monitor session 2 source interface Gi3/1
monitor session 2 destination interface Fa4/4
end
576
