10-22-2009 12:02 PM - edited 03-04-2019 06:28 AM
Hello Chaps,
I need to run neflow to capture the traffic through a router. This router also needs to be configured as a bridge (using IRB). I did the configs but when I use th "show ip flow export", I see that, no export is happening.
Can u help me with the direction to a document or procedure perform this task?
Solved! Go to Solution.
10-23-2009 01:29 AM
10-22-2009 02:29 PM
On which interface you configured the command ?
10-22-2009 02:52 PM
Can we see your config? Particularly the part that shows the interface configuration for netflow?
10-23-2009 01:27 AM
Hello all,
Attached is the relevant part of the config.
Below is also the same:
Rgds.
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 2
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
bridge irb
interface Ethernet0/0
no ip address
half-duplex
bridge-group 1
interface FastEthernet0/0
no ip address
ip route-cache flow
speed auto
bridge-group 1
interface BVI1
ip address 172.25.5.82 255.255.255.224
ip classless
ip flow-export source BVI1
ip flow-export version 5
ip flow-export destination 172.25.5.81 9999
no ip http server
snmp-server community public RW
snmp-server ifindex persist
control-plane
bridge 1 protocol ieee
bridge 1 route ip
10-23-2009 01:29 AM
You need:
ip route-cache flow
under BVI, not F.E.
