Webcast-Catalyst9k
network boot using tftp
I have 3725 router. due to insufficient flash i would like to boot the router using tftp.
I want to know command to proceed.
will i be able to download 64 mb file into memory.
1 REPLY
Hall of Fame Super Gold
Re: network boot using tftp
kamalnath
You would need to verify that you have enough memory on your 3725 to run this new version of IOS. But if you do then you can use this command:
boot system tftp
Rick
160
