Network issue at remote location
Sandeep Choudhary
Hello Everyone,
I am trying to ping my remote location router then am getting lots of Request timeout and one of the SAP application is very slow.
Can you please help me to find the issue.
Mp PC(HQ)------------------------------->Via Tunnels-------------------------->Branch Location router(International)
Brach office have 10Mbps line and connected with 2 tunnels to HQ.
HQ have 100Mbps line for the external communicational.
Here I attached the ping output to remote location from hq.
what could be the problem ??????
the problem is not in the GRE tunnel and is not in the IpSec.
the problem is not in the  firewall.
packets are lost in the  service provider network, tell them about this. and show them ping output
you can also make
HARCVPN2#tracerote 82.99.163.2 source 212.185.41.196
you only can check connectivity from HQ_router to provider equipment and from Branch_Location_router
plz rate post if it hepled
10 Replies 10
bmrodrigues
Are the tunnels GRE ?
Can you check on the routing table if you have the remote branch subnet path thru more than one tunnel ?
Is there a firewall between ?
yes there is a firewall.
we have 2 tunnels from the HQ.......yes these tunnels are GRE.
here is the tunnel config on the remote side:
interface Tunnel1
description *** Tunnel 1 ***
bandwidth 2000
ip address 10.13.75.2 255.255.255.252
ip mtu 1300
ip tcp adjust-mss 1260
tunnel source Remote provider IP
tunnel destination HQ Provider IP
tunnel protection ipsec profile vpn_profile_hasel_aes
interface Tunnel2
description *** Tunnel 2 ***
bandwidth 2000
ip address 10.13.175.2 255.255.255.252
ip mtu 1300
regards
make
ping destination Remote provider IP from source HQ Provider IP repeat 100 and put here
how can i ping from my source ip provider to remote.
I can ping from my local network to the remote provider....
If can then pleasee tell me.
Here is the result of ---HQ local network to remote provider ping:
when connected to HQ_router where tunnel interfaces
so make
ping  (Remote_provider_IP) source (HQ_Provider_IP) repeat 100
Here is the output:
HARCVPN2#ping 82.99.163.2 source 212.185.41.196 repeat 100
Sending 100, 100-byte ICMP Echos to 82.99.163.2, timeout is 2 seconds:
Packet sent with a source address of 212.185.41.196
Success rate is 74 percent (74/100), round-trip min/avg/max = 32/33/36 ms
you can also make
Jeff Van Houten
Level 5
Level 5
Do you have any qos policies attached to the external interfaces?
Hi Jeff,
We do not have any qos policies to the external interfaces.
here are the config of the tunnels:
interface Tunnel175
description *** xyz ***
bandwidth 2000
ip address 10.13.75.1 255.255.255.252
ip mtu 1300
tunnel source 195.243.205.104
tunnel destination 82.99.163.2
tunnel protection <.....................................>
interface Tunnel275
bandwidth 2000
ip address 10.13.175.1 255.255.255.252
ip mtu 1300
tunnel source 212.185.41.196
and same tunnel configration on the remote router for tunnels.
still we are facing 20% packet loss.
hey guys, even we matched the port setting as the provider interface gave:
1.still we are getting request timeout while traferring file between HQ and remote location.
2. Now we have delay of around 200ms(normal delay is 35 ms).
CAD is using 75% of the bandwidth....................................
what will be the issue
Please check
Sandeep
