Network Load Balance with Failover
krybabie
I have 2 X cisco 2610 (router A and B)
also 1 X cisco 3620 (router C)
Router a & b have a 1 MB serial Link
Router B is main access router
Router A and C are connected via 2 X wireless links.
I need the following
RouterB to control Failover. If the 2 wireless links die then it must fail over to the serial
Router C must control load balancing 50/50.
I want to do this with static routes
could i do the following on router C
ip route 0.0.0.0 0.0.0.0 192.168.166.137 5
ip route 0.0.0.0 0.0.0.0 192.168.166.145 5
then on router B
ip route 0.0.0.0 0.0.0.0 192.168.166.4 5
ip route 0.0.0.0 0.0.0.0 192.168.166.133 10
Would that all work correctly
Malcolm
5 Replies 5
chirag-pandya
Hello krybabie ,
First thing is that u note that u want to make load balancing between ur routers if ur wireless link goes down,
see there r 2 link from router a to c if bothe will be down thenu have only 1 link from router a to c,
see main thing is that u need load balancing where u have multiple links or more than 1 link to same destination,
and if u want to make router b to share load betwen router a and c so both r directly connected with router b so for routing purpose u need only 1 or 2 commands and there is no need to configure floting route
router C
router A
ip route 0.0.0.0 0.0.0.0 (put serial no of router b or ip address of router b)
If u have any doubt thn tell me....
Chirag Pandya
i messed up in my blurb a bit
Router A is main access router
Router B is not main access router
Malcolm
Malcolm,
I recommend to enable routing protocol like eigrp and use sub-interface instead of secondary ip address. Eigrp will do everything for you.
If you have to use static routes, check the feature called reliable static route with object tracking.
Hope this helps.
Malcolm,
Hope this helps.
That feature seems to only work with DDR (dial on demand routing) - this is not what i am looking for ...
Malcolm
