06-18-2009 09:03 AM - edited 03-04-2019 05:10 AM
Is there a better way to implement a network static NAT than entering every IP address in the subnet. Its the only way I've found that actually functions properly. (Various versions of 12.4T have functioned differently.)
Current IOS is 12.4(15)T9
06-18-2009 09:07 AM
Try this instead:
ip nat inside source static network 192.168.2.0 10.168.16.0 /24 route-map rmap 1
HTH,
John
07-02-2009 10:12 AM
route-maps are no longer supported on ip nat inside source static network command
(config)#$de source static network 192.168.2.0 10.1.87.0 /24 ?
extendable Extend this translation when used
mapping-id Associate a mapping id to this mapping
no-alias Do not create an alias for the global address
no-payload No translation of embedded address/port in the payload
redundancy NAT redundancy operation
