new BGP feature. Load sharing over unequal cost links
Hi All,
BGP now has a feature to allow some load balancing between unequal eBGP peers.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t2/ftbgplb.htm
I am going to try this out either this week or next and am looking around to see if anyone else implemented it.
If so, would you mind sharing how the change went for you and what gotchas to look out for?
thanks very much
amanda
  • WAN Routing and Switching
Re: new BGP feature. Load sharing over unequal cost links
The only thing I would point out is that this feature follows the "bandwidth" configure on the interfaces to determine what traffic share will be assign to each neighbor. Nevertheless, you have to remember that the load-sharing will be based on the 16 CEF buckets and might not be exactly in the same proportion you expect.
Hope this helps,
So far, so good. I managed to get the load balancing up and running on a trial basis using 3 routes.
I have decided to try and also add the default-route into the list of routes that load-share; but for some reason, the default route is not making it into multipath... let alone load sharing.
Do i need to remove the unequal cost load-sharing configuration and make it work in multipath before trying to re-enable the unequal cost load sharing?
You should be able to get the unequal load-share functionality to work as well as with any other routes. Make sure you reset the BGP session after you configure the dmz-link feature.
I just did a quick test and here's the output:
R1#sh runn | beg bgp
router bgp 1
no synchronization
bgp log-neighbor-changes
bgp dmzlink-bw
neighbor 192.168.12.2 remote-as 2
neighbor 192.168.12.2 dmzlink-bw
neighbor 192.168.16.6 remote-as 2
neighbor 192.168.16.6 dmzlink-bw
maximum-paths 2
no auto-summary
R1#sh ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 2
Paths: (2 available, best #1)
Multipath: eBGP
Advertised to update-groups:
192.168.12.2 from 192.168.12.2 (2.2.2.2)
Origin IGP, localpref 100, valid, external, multipath, best
DMZ-Link Bw 25 kbytes
192.168.16.6 from 192.168.16.6 (6.6.6.6)
DMZ-Link Bw 50 kbytes
R1#sh ip cef 0.0.0.0 0.0.0.0
0.0.0.0/0, version 23, epoch 0, per-destination sharing
0 packets, 0 bytes
via 192.168.12.2, 0 dependencies, recursive
traffic share 2
next hop 192.168.12.2, Serial2/0 via 192.168.12.0/30 (Default)
valid adjacency
via 192.168.16.6, 0 dependencies, recursive
traffic share 5
next hop 192.168.16.6, Serial3/0 via 192.168.16.0/24 (Default)
valid adjacency
0 packets, 0 bytes switched through the prefix
tmstats: external 0 packets, 0 bytes
internal 0 packets, 0 bytes
Hope this helps,
thanks mate, but I am sure you are right; but i had to backout of this project yesterday afternoon. My router crashed with a software error and i believe it may have had something to do with this configuration because this is the only thing I had changed on the router and it has not done a crash before.
I am afraid i am going to have to go back to the tried and true divide and conquor method and force some traffic down one path and some down the second.
226
