New MOE Connection Problems
Ed Willson
Hi All,
   I've just turned up a new MPLS MOE connection between a new site and and the HQ.  Currently all the other branches are running another providers MPLS network, and we're working on transitioning to this new carrier.  I was expecting to route to the IP I was given by the carrier, but it's not working and I'm at a loss as to why.
Here's the setup:
Headquarters has a 2800 router and the remote site has a 3750x switch.
The carrier gave me a /30 for inside addresses at each end.  I can ping the inside address from each location, but I cannot ping any other interfaces that are on one side from the other.
Any help would be great.  I've been banging my head for a dozen hours so far.
    Skymeat
Peter Paluch
Hello Ed,
From what you wrote I assume that from one CE router, you can ping the PE/CE link on the other CE router, however, you can not ping behind that CE router - am I correct? What kind of MPLS interconnection is this - L2 pseudowire or L3 VPN? I assume the latter.
If that is true then in my opinion, the problem is in the exchange of the routing information between your sites and the MPLS L3VPN. You are using static routing but in MPLS L3 VPN, it is necessary for provider's PE routers to know what networks are located on your individual sites. I do not assume that this knowledge has been put into the PE routers statically by your service provider; instead, I believe, you should run a routing protocol between your CE and PE routers. The exact details should have been told you by your service provider.
Another problem I see here is the definition of the default route on your 3750 switch: it is always wrong to define a static default route out via a multiaccess interface, such as Vlan300. That makes the route appear as directly connected, and the switch assumes that all stations within that network are directly connected. Surely, the entire internet is not directly sitting on your Vlan300 This makes your switch to totally depend on ProxyARP of the neighboring PE router, causes exorbitantly large ARP tables and traffic, and if the ProxyARP is deactivated, it does not work at all. I strongly recommend removing the line
ip route 0.0.0.0 0.0.0.0 Vlan300
and replace it with
ip route 0.0.0.0 0.0.0.0 216.206.123.177
Beware that doing this remotely may cause lock you out from the device - it is better performed from a console, or by first entering the second command, and only then removing the first command (the existing one).
Best regards,
Peter
7 Replies 7
Ed Willson
Here's the HQ config.  The interface in question is g 0/1.832:
HQ#show run
Building configuration...
Current configuration : 5470 bytes
version 12.4
service password-encryption
hostname FWG-Hen-RTR-MPLS
boot-start-marker
boot-end-marker
card type t1 0 0
card type t1 0 1
logging message-counter syslog
logging buffered 10000000
enable secret 5
no aaa new-model
no network-clock-participate wic 0
no network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
archive
log config
  hidekeys
controller T1 0/0/0
fdl ansi
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/0/1
fdl ansi
controller T1 0/1/0
fdl ansi
controller T1 0/1/1
fdl ansi
class-map match-all Oracle
match access-group 160
class-map match-all RDP
match access-group 102
class-map match-all voice-priority
match access-group 101
policy-map POLICY1
class voice-priority
  set ip precedence 5
    priority percent 40
class RDP
    bandwidth percent 20
  set ip precedence 4
class Oracle
  set ip precedence 4
    bandwidth percent 15
class class-default
    fair-queue
  set ip precedence 0
buffers tune automatic
interface Multilink1
ip address 192.168.253.2 255.255.255.252
ip flow ingress
ip flow egress
ppp multilink
ppp multilink interleave
ppp multilink group 1
ppp multilink fragment disable
service-policy output POLICY1
interface GigabitEthernet0/0
ip address 10.10.30.1 255.255.0.0 secondary
ip address 10.10.30.2 255.255.0.0
ip flow ingress
ip flow egress
duplex full
speed 100
interface GigabitEthernet0/1
description SWI_2
no ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/1.832
encapsulation dot1Q 832
ip address 63.156.54.138 255.255.255.252
ip flow ingress
ip flow egress
interface Serial0/0/0:0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
interface Serial0/0/1:0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
interface Serial0/1/0:0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
interface Serial0/1/1:0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
interface Serial0/2/0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
interface Serial0/3/0
bandwidth 1536
no ip address
ip flow ingress
ip flow egress
encapsulation ppp
ppp multilink
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.10.3
ip route 10.5.0.0 255.255.0.0 216.206.123.177
ip route 10.16.0.0 255.255.0.0 192.168.253.1
ip route 10.20.0.0 255.255.0.0 192.168.253.1
ip route 10.21.0.0 255.255.0.0 192.168.253.1
ip route 10.22.0.0 255.255.0.0 192.168.253.1
ip route 10.23.0.0 255.255.0.0 192.168.253.1
ip route 10.30.0.0 255.255.0.0 192.168.253.1
ip route 10.40.0.0 255.255.0.0 192.168.253.1
ip route 10.50.0.0 255.255.0.0 192.168.253.1
ip route 10.60.0.0 255.255.0.0 192.168.253.1
ip route 10.70.0.0 255.255.0.0 192.168.253.1
ip route 10.80.0.0 255.255.0.0 192.168.253.1
ip route 10.85.0.0 255.255.0.0 192.168.253.1
ip route 10.90.0.0 255.255.0.0 192.168.253.1
ip route 10.100.0.0 255.255.0.0 192.168.253.1
ip route 10.110.0.0 255.255.0.0 10.10.10.3
ip route 10.120.0.0 255.255.0.0 192.168.253.1
ip route 10.130.0.0 255.255.0.0 192.168.253.1
ip route 74.123.58.128 255.255.255.240 192.168.253.1
ip route 74.123.60.32 255.255.255.240 192.168.253.1
ip route 140.85.0.0 255.255.0.0 192.168.253.1
ip route 141.146.128.0 255.255.128.0 192.168.253.1
ip route 172.25.106.0 255.255.255.0 192.168.253.1
ip route 172.25.234.192 255.255.255.192 192.168.253.1
ip route 172.26.16.0 255.255.255.0 192.168.253.1
ip route 172.26.74.0 255.255.255.0 192.168.253.1
ip route 172.26.75.0 255.255.255.0 192.168.253.1
ip route 192.168.0.0 255.255.255.0 192.168.253.1
ip route 192.168.253.0 255.255.255.0 192.168.253.1
ip route 216.206.123.176 255.255.255.252 GigabitEthernet0/1.832
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 10.10.80.9 2055
logging trap notifications
logging source-interface GigabitEthernet0/0
logging 10.10.80.9
access-list 101 permit ip any any dscp ef
access-list 102 permit tcp any eq 3389 any
access-list 102 permit tcp any any eq 3389
access-list 160 permit ip any 172.25.106.0 0.0.0.255
access-list 160 permit ip any 172.25.234.192 0.0.0.63
access-list 160 permit ip any 172.24.106.0 0.0.0.255
access-list 160 permit ip any 172.24.234.192 0.0.0.63
snmp-server community luigi RO
snmp-server community locutus RW
snmp-server ifindex persist
snmp-server trap-source GigabitEthernet0/0
snmp-server enable traps config
snmp mib persist circuit
control-plane
line con 0
password 7
login
line aux 0
password 7
login
modem InOut
transport input all
stopbits 1
flowcontrol hardware
line vty 0 4
password 7
login
scheduler allocate 20000 1000
end
HQ#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.10.10.3 to network 0.0.0.0
S    149.85.0.0/16 [1/0] via 192.168.253.1
     149.146.0.0/17 is subnetted, 1 subnets
S       141.146.128.0 [1/0] via 192.168.253.1
     172.25.0.0/16 is variably subnetted, 2 subnets, 2 masks
S       172.25.234.192/26 [1/0] via 192.168.253.1
S       172.25.106.0/24 [1/0] via 192.168.253.1
     172.26.0.0/24 is subnetted, 3 subnets
S       172.26.16.0 [1/0] via 192.168.253.1
S       172.26.74.0 [1/0] via 192.168.253.1
S       172.26.75.0 [1/0] via 192.168.253.1
     216.206.123.0/30 is subnetted, 1 subnets
S       216.206.123.176 is directly connected, GigabitEthernet0/1.832
     10.0.0.0/16 is subnetted, 19 subnets
C       10.10.0.0 is directly connected, GigabitEthernet0/0
S       10.5.0.0 [1/0] via 216.206.123.177
S       10.30.0.0 [1/0] via 192.168.253.1
S       10.16.0.0 [1/0] via 192.168.253.1
S       10.22.0.0 [1/0] via 192.168.253.1
S       10.23.0.0 [1/0] via 192.168.253.1
S       10.20.0.0 [1/0] via 192.168.253.1
S       10.21.0.0 [1/0] via 192.168.253.1
S       10.40.0.0 [1/0] via 192.168.253.1
S       10.60.0.0 [1/0] via 192.168.253.1
S       10.50.0.0 [1/0] via 192.168.253.1
S       10.70.0.0 [1/0] via 192.168.253.1
S       10.90.0.0 [1/0] via 192.168.253.1
S       10.80.0.0 [1/0] via 192.168.253.1
S       10.85.0.0 [1/0] via 192.168.253.1
S       10.110.0.0 [1/0] via 10.10.10.3
S       10.100.0.0 [1/0] via 192.168.253.1
S       10.120.0.0 [1/0] via 192.168.253.1
S       10.130.0.0 [1/0] via 192.168.253.1
S    192.168.0.0/24 [1/0] via 192.168.253.1
     63.0.0.0/30 is subnetted, 1 subnets
C       63.156.54.136 is directly connected, GigabitEthernet0/1.832
     192.168.253.0/24 is variably subnetted, 3 subnets, 3 masks
C       192.168.253.1/32 is directly connected, Multilink1
C       192.168.253.0/30 is directly connected, Multilink1
S       192.168.253.0/24 [1/0] via 192.168.253.1
     74.0.0.0/28 is subnetted, 2 subnets
S       74.123.60.32 [1/0] via 192.168.253.1
S       74.123.58.128 [1/0] via 192.168.253.1
S*   0.0.0.0/0 [1/0] via 10.10.10.3
Here's the remote site.  The interface in question is vlan 300:
Remote#show run
Current configuration : 2158 bytes
version 12.2
no service pad
hostname FRS-Van-Swi-ACore
boot-start-marker
boot-end-marker
enable password 7
no aaa new-model
switch 1 provision ws-c3750x-24
system mtu routing 1500
ip routing
vtp domain Stuff
vtp mode transparent
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 300,1000
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
ip address 10.5.41.1 255.255.0.0
interface Vlan300
ip address 216.206.123.178 255.255.255.252
ip classless
no ip http server
ip sla enable reaction-alerts
logging 10.10.80.9
line con 0
line vty 0 4
password 7
login
line vty 5 15
login
end
Remote#show ip route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
C       216.206.123.176 is directly connected, Vlan300
     10.0.0.0/16 is subnetted, 1 subnets
C       10.5.0.0 is directly connected, Vlan1
S*   0.0.0.0/0 is directly connected, Vlan300
FRS-Van-Swi-ACore#show int tru
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/1     on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/1     1-4094
Port        Vlans allowed and active in management domain
Gi1/0/1     1,300,1000
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     1,300,1000
Peter Paluch
Hello Ed,
and replace it with
Best regards,
Peter
Peter,
    Thanks for the heads up on default route.  I was at the point of just trying things and banging away senselessly at the keys when I posted those configs.
    I Just got done talking to the provider, and they forgot to add our networks to thier routers.  So nothing can be done till Monday, but I'm hoping that it can be resolved then.  I'm pretty sure you called the problem correctly.
   Ed
Hi Ed,
Man... they're deploying a MPLS L3 VPN infrastructure and forget to deal with routing which is the very essence of this VPN type? I can't believe my eyes
Nevertheless, please let me know if they got it running on Monday.
Best regards,
Peter
The proider added our internal networks and everything's looking peachy.  Thanks for the help!
   Ed
Hi Ed,
Don't mention it - I actually did not help at all here. Glad to see you've got it working!
Best regards,
Peter
