12-05-2006 01:26 PM - edited 03-03-2019 02:55 PM
i have a new t-1 i want to turn up using a VWIC-2MFT-T1 on both ends of the circuit. normally i would use a wic 1dsu t1 v2 on one end and a VWIC-2MFT-T1 on the other. i installed the VWIC-2MFT-T1 with the standard controller configuration (linecode b8zs, clocksource line, framing esf) and when i placed the t-1 in the controller i get interface serial 0/0:0 up line protocol down. i also configured the serial interface after i configured the controller.
my question is - is there any other configuration i may be missing since i am using a different hardware setup?
below is a capture of the interface while trying to turn up the circuit.
Serial0/1/0:0 is up, line protocol is down
Hardware is GT96K Serial
Description: T-1 to yomammas house
Interface is unnumbered. Using address of FastEthernet0/0.10 (10.10.154.1)
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
reliability 217/255, txload 1/255, rxload 1/255
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
CRC checking enabled
Last input 01:05:27, output 00:00:01, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
22 packets input, 1128 bytes, 0 no buffer
Received 7 broadcasts, 2 runts, 6 giants, 0 throttles
541 input errors, 541 CRC, 471 frame, 349 overrun, 0 ignored, 282 abort
511 packets output, 14144 bytes, 0 underruns
0 output errors, 0 collisions, 16 interface resets
18 carrier transitions
Timeslot(s) Used:24, SCC: 0, Transmitter delay is 0 flags
12-05-2006 03:42 PM
Jerry,
Who is providing the clocking ? The telco ?
What's the Serial status on the router at the other end ? It could be a provisioning problem here, have you contacted the telco carrier ?
12-06-2006 03:16 AM
Can you provide to us the results of a SHOW CONTROLLER T-1 to see the status of layer 1 of the T-1. Is this T-1 actually provisioned for B8ZS/ESF or possibly D4 framing??
12-06-2006 05:25 PM
Possible that you need to set encapsulation ppp? If this T1 is not encapsulated with HDLC, it could cause issues (ie, like a MPLS circuit).
-Tim
12-06-2006 05:54 PM
Make sure under your 'controller t1 0/1/0' you have 'channel-group 0 timeslots 1-24 speed 64'
From the look of your output, you're only using timeslot 24 now.
12-07-2006 08:31 AM
good point - i'll give it a shot Friday and post.
thanks,
12-06-2006 08:21 PM
I am having a similiar but different issue with a WIC-1DSU-T1-V2 on 1841 Cisco Router. I am following guide lines on-line per a WIC-1DSU-T1 (without V2) which is configured with service-module commands rather than controllers but I can't bring the status of the Serial 0/0/0 to up. Can someone explain to me what I am missing please. I've tried the following:
Interface serial 0/0/0
service-module t1 clock source line
service-module t1 timeslots 1-24 speed 64
service-module t1 framing esf
service-module t1 linecode b8zs
ip address 192.168.1.1 255.255.255.248
encapsulation ppp
fair-que
no shutdown
but only the following saves or shows up after a "show run":
"interface Serial0/1/0
encapsulation ppp
fair-queue
service-module t1 timeslots 1-24"
and here is the full "show int"
#show int ser 0/1/0put errors, 0
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Closed, loopback not set
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:17:25
Conversations 0/0/256 (active/max active/max total)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 36 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
Thank you.
12-07-2006 03:53 AM
The issue with your Serial 0/1/0 is that your CTS is down because your DCD is down. Your DCD is down because the remote DSR is down. You need to look at the remote end to verify they are up OK....
