NEWBIE NEEDS HELP
sandman420
Hello all,
So new to cisco it's not funny! I can cli configure ip and route and flash ios and not a whole lot else. I have seen some configurations for connecting wic-1enet to pppoe session for dsl, but these are all captures of their startup config if I'm not mistaken. I guess my question is, is what I see in the startup-config's the actuall commands I would need to type in cli? I keep seeing something about a tool that you can make the config and upload it to the router tftp? anyone know what it's called and where I might be able to download it?
Thank you
18 Replies 18
sandman420
well, I figured out i could edit in wordpad, and copied a working script from a site and modified for me...won't work though, and i don't know anyway (commands) to troubleshoot to figure out what part isn't working. currently running c1700-sy7-mz.122-4.XL3 and have c1700-k9o3sy7-mz.123-13 that i can throw on it if it is a simple matter of features. Anyway...here is script...let me know if i messed something up please:
! NVRAM config last updated at 23:53:50 Central Sat Apr 12 2008
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname SANDBOX_1751
memory-size iomem 20
clock timezone Central -6
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip name-server 64.91.3.46 (DSL DNS SERVER IP?)
ip name-server 64.91.3.60 (DSL DNS SERVER IP?)
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface FastEthernet0/0
description Lan
ip address 1.1.1.3 255.255.255.0
ip nat inside
speed auto
full-duplex
interface Ethernet0/0
description iburst
no ip address
ip nat outside
ip tcp adjust-mss 1452
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap password 0 pass
ppp pap sent-username XXXX password 0 XXXXX
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
ip pim bidir-enable
access-list 1 permit any
access-list 1 permit 1.1.1.0 0.0.0.255
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
login
no scheduler allocate
end
Mark
Without some indication of what is not working it is hard to give you good advice. I have looked at the config and the things that most often cause problems seem to be reasonable:
- there is a static default route, so routing is taken care of.
- you have configured address translation. Though I would ask you to make 1 change in it. Instead of this version of access list
please make this the access list
I have seen some issues where the access list for address translation uses permit any.
Other than this can you tell us how you are testing the router and what is not working? Does it connect to a provider device? Does it get assigned an IP address on the dialer interface?
Rick
Rick
so just take out the "permit any"? Are my versions of the ios compatible? I just flashed to the 12.3(13) k9 version last night and it didn't seem to make any difference.
I really don't know a whole bunch of commands being so new (and it's kind of hard searching the internet for this stuff), so the only thing I did try was show ip on the dialer 1 (which I can't even remember the full command for right now), and all it said was something to the effect of IP address would be assigned by the ppp or something instead of showing the actual ip. If someone could show me some commands to find out wether or not the dialer is actually making a connection, or wether the pppoe login isn't getting authenticated or what would be really helpful.
Thank you,
Mark
Mark
Yes just take out the permit any.
I am not sure what you are asking about IOS compatible. For what you are trying to do so far I believe that either of them would work. In the long term I believe that you are better off using the 12.3(13)k9.
I would probably use commands like show ip interface brief or show ip route and see if they show addresses or routes on the dialer.
Rick
Rick
Thanks. I will try that when I get home tonight.
So, "show ip dialer 1 brief" would be the command I want to use to see if the dialer 1 interface has gotten an ip from the PPPoE server? What about authentication. Can we take it back a step and use a command to see wether or not the PPPoE session even made contact out of the wic-1enet card?
No Go. See if this means anything to you.
Capture Attached
Mark
I see the line protocol on interface ethernet 0/0 go to up. So it is connected to something. But it looks like the ppp negotiation is not taking place. Can you clarify what you are connected to on interface ethernet 0/0?
I would suggest that perhaps the next step is to run some debugs. I would probably start with debug ppp negotiation and perhaps debug ppp authentication. run these debugs and post any output. You might want to configure a somewhat larger logging buffer to contain the debug output. Perhaps something like logging buffer 32768. Then you can use the show log command to see the output in the logging buffer on the router. You can also see the debug output on the console port if you are connected on the console. Or if you telnet into the router then use the terminal monitor to see the debug output on your terminal.
Rick
Rick
Rick,
eth 0/0 is patched to a westell (I think 5104 or 6104) dsl modem/router that is in bridge mode so my cisco can hold the pppoe login and session. I can't figure out where I saw this in another forum, but some said that the authentication might need to be changed from chap/pap whatever to something else....not totally sure, and again, I am very much new to ios commands, although I'm learning a lot.
I set the eth 0/0 for full duplex, just because I read somewhere that the wic-1enet card won't auto-neg and my linksys router always showed a full duplex connection when it was hooked up to the dsl modem. If it helps, my carrier is Centurytel.
I'll try my best to issue the debug commands, pretty sure I can do that, but finding the info to capture might take me a little to figure out, unless everything will be displayed with the "show log" command.
Thank you,
Mark
Mark
The show log command is the easy way to get all the debug output.
Rick
Rick
Oh, forgot to mention it'll be a couple of hours before I'm at that location to hook up the dsl to it and run a debug. Any specific time that this should be in debug mode or does the debug commands only run for whatever data is already there to be logged? If it is a simple switch command, I assume no debug .... would be the off switch for that command?
Thank you,
Mark
Mark
debug runs in real time and reflects activity that occurs while it is running. I would suggest turn on the debug and after it is running go into config mode to the ethernet interface and do a shutdown, wait a bit, then do a no shutdown. This should initiate activity on the interface for the debug to process.
Yes no debug ... is the way to turn it off.
Rick
Rick
Rick,
I don't know if I gave it enough time or what; just seems like not much info to me. Here it is:
SANDBOX_1751#show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled)
Console logging: level debugging, 32 messages logged, xml disabled
Monitor logging: level debugging, 0 messages logged, xml disabled
Buffer logging: level debugging, 1 messages logged, xml disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 37 message lines logged
Log Buffer (32768 bytes):
20:14:17: %SYS-5-CONFIG_I: Configured from console by console
SANDBOX_1751#debug ppp negotiation
PPP protocol negotiation debugging is on
SANDBOX_1751#debug ppp authentication
PPP authentication debugging is on
SANDBOX_1751#config term
Enter configuration commands, one per line. End with CNTL/Z.
SANDBOX_1751(config)#int eth 0/0
SANDBOX_1751(config-if)#shutdown
20:16:00: %LINK-5-CHANGED: Interface Ethernet0/0, changed state to administratively down
20:16:01: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to down
SANDBOX_1751(config-if)#no shutdown
20:16:28: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
20:16:29: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
SANDBOX_1751(config-if)#^Z
SANDBOX_1751#
20:16:40: %SYS-5-CONFIG_I: Configured from console by console
Console logging: level debugging, 37 messages logged, xml disabled
Buffer logging: level debugging, 6 messages logged, xml disabled
Trap logging: level informational, 42 message lines logged
SANDBOX_1751#
Mark
The debug seems to show that there is no ppp negotiation or authentication.
Rick
Rick
ok. I kind of figured that was the case. How do I make it? Different authent method or something?
