newbie question, lost connection when ip routing enabled?
sc.bill.lee
hi there,
i am configuring a 3560, everthing is fine until i enable the "ip routing"
i lost connection to all vlan, any idea?
thanks in advance.
18 Replies 18
cadet alain
try changing this command: ip default-gateway x.x.x.x into ip route 0.0.0.0 0.0.0.0 x.x.x.x
Regards.
Alain
Bill
If the suggestion from Alain does not solve your issue then I suggest that you post the configuration of the switch. This might help us to identify the issue.
Rick
Rick
sc.bill.lee
Sorry bros, let me make my question more clear
actually, my situation is..
the core switch 3750 serves voice/servers/etc..all the vlans, routings (e.g. routing all traffic excluding 10.x.x.x to ISP_A)
a newly added Room B, got an old 3560, made truncking to 3750
Need to achieve:
users in room B use ISP_B for internet, all other traffic goes back to 3750
Question:
is that i need to do routes in 3560? is that i need to enable ip routing in 3560?
post the config from 3750 and 3560.
Regards.
Alain
Bill
Given what is in the drawing I would think that you would need to enable routing on the 3560. You would want to configure a default route that would send traffic from the local VLANs out to ISP B. And you would want routes on the 3560 that would send traffic for the VLANs/subnets in room A to the 3750.
Rick
Rick
3750 and 3560 have common vlan now, they can talk to each other,
but when I tried to enable "ip routing" in 3560, I lost connection to the 3560, any idea?
You probably still have  "ip default-gateway" . This works only for a layer2 siwtch only. So, once you enable ip routing this functionality is no more valid and you loose connection as the switch doesnt have a default gateway.
but you should still be able to log into it from 3750 and check "sh ip route" and it will show you nothing.
Hope this give you some idea.
hi,
to add to what rick mentioned make sure you have common vlans between the switches that need to talk and configure a trunk and enable ip routing on the 3560. This will enable the vlans to talk to each other.
For the internet traffic configure a default route on the 3560 and that will allow traffic destined for internet to go out via ISP B.
Kishore
sc.bill.lee
C3560-GZH-01#sh run
Building configuration...
Current configuration : 4399 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname C3560-GZH-01
enable secret
no aaa new-model
system mtu routing 1500
vtp domain SCGZHnetwork
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 1 priority 36864
vlan internal allocation policy ascending
vlan 8
name PBX
vlan 9
name servers
vlan 19
name Network-devices
vlan 160
name Workstations
interface GigabitEthernet0/1
switchport access vlan 160
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
description ***ASA 5510***
switchport access vlan 9
interface GigabitEthernet0/24
description ***PABX***
switchport access vlan 8
interface GigabitEthernet0/25
description 3560_3750_Fibre
switchport mode trunk
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
no ip route-cache
interface Vlan8
ip address 10.161.8.2 255.255.255.0
no ip redirects
no ip unreachables
ip accounting output-packets
interface Vlan9
description ***----Server VLAN----***
ip address 10.161.9.2 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan19
ip address 10.161.19.2 255.255.255.0
no ip route-cache
ip classless
ip http server
control-plane
line con 0
login local
line vty 0 4
login local
line vty 5 15
login
end
C3560-GZH-01#
Currently the switch is acting like a Layer2 switch. Also, I cant see any default GW? Where is the switch going to send the traffic to?
yes, it's still acting as layer 2, all the traffic is now going through another 3750 connected to g0/25
what I need to achieve is making all the clients connected to 3560 going internet by the firewall connected to 3560 g0/23
but when I enable ip routing in 3560, i lost connection to it....
From looking at your configuration, it appears that all your ports on the 3560 are on VLAN160. I don't see a vlan interface for VLAN160 on the 3560? Where is the default gateway for VLAN160 located? If you want the 3560 in Room B to use the ISP from B you will need a vlan interface on 3560 and point a default route to the ASA, and then the ASA should hae a default route going towards the ISP next hop.
actually all vlan is in room A 3750, i would like to make 3560 all traffic goes ISP_B except traffic for 10.x.x.x
No Connectivity After IP Routing is Enabled
One of the most common issue people face is the loss of connectivity  once IP routing is enabled on the switch. A common cause for this issue  is the command used to specify the default gateway for the device.
If IP routing is not enabled on the device, the command is ip default-gateway.
3750-1#ip default-gateway A.B.C.D
!--- where A.B.C.D is the IP address of the default router
If IP routing is enabled, use the ip route command in order to specify the default router for that device.
3750-1#ip route 0.0.0.0 0.0.0.0 A.B.C.D
Taken from the link
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807ccc79.shtml
Hope this helps
