Newbie Static Routing Issue
Hello all,
Having no previous Cisco experience, I'm really struggling to get to grips with what should be a very simple staic route configuration on an ASA 5505.
Basically,I'm using the ASA5505 as my default gateway, however I have another router (Speedtouch 608WL) which serves a site to site VPN to another office. I've configured a static route point as per the attachment however, I cannot access resource on the remote network. is there something really simple that I'm missing. Please accept my apologies for many lack of basic understanding on how these devices work, I've been thrown i the deep end big time on this one. Any help you cold provide, even if it's pointing me in the direction of some tutorials or other resources ould be greatly appreciated.
Many Thanks
Josh,
There are few things you might want to check.
1) Is the next hop 192.168.11.253 the IP of the router and is it reachable from the ASA?
2) On the router, is the VPN up in the first place.
It would be nice to have a topology diagram. Can you provide one?
Anand
Many thanks for your response.
Yes, 192.168.11.253 is the IP address of the router servicing the IPSec VPN to the 192.168.14.0 network. Another Idenitcal Speedtouch is at the other end. If I change my default gateway address to 192.168.11.253 I can access all the resources on the 192.168.14.0 network - which leads me to believe VPN is operational.
If I ping 192.168.11.253 from the ASA I get the following response:
However, If I try to ping the router at the other end of the gateway (192.168.14.253) from the adsm I get the following response:
Please find a very crude network diagram overview diagram below:
Many Thanks for your help thus far. Please let me know if you need any further information.
Forgot to say, the double arrow denotes a IPSec VPN between sites. Thanks again.
Purple
the static route you entered is wrong because the 192.168.14.0 network is not on the inside interface but the outside one.
Where is the inside network communicating through VPN located? Which device is doing NAT ?
Can you post config of ASA and router.
Regards.
Alain
Thanks Alain.
I might not have a full understanding, and could be wrong, but I was sure it was on the Inside interface, as it's connect via a switch on port 2 (which is configured as Inside). Am I wrong?
Unfortunatley I cannot post the full config for the Speedtouch as it's managed by a third party. I could get the config sent over, howver , it could take a couple of days. Though RE said router, as soon as I make the Speedtouch my Default gateway I can access all the nessecary resources. In my understanding (and appreicate I could be wrong) doesn't that point to it performing it's role correctly.
Thanks again for your help. Please find the config for the ASA below:
Result of the command: "show running-config"
: Saved
ASA Version 8.3(1)
hostname ciscoasa
enable password uHrzqROQ0KCd5V0G encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.11.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 192.168.11.23
name-server 192.168.11.28
dns server-group OpenDns
name-server 208.67.222.222
name-server 208.67.220.220
dns-group OpenDns
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
route inside 192.168.14.0 255.255.255.0 192.168.11.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.11.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.11.5-192.168.11.253 inside
threat-detection basic-threat
threat-detection statistics host number-of-rate 3
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:b424fd365a8f219b0e2803af7e12dac1
: end
Purple
looking at your config you are not wrong indeed but why did you connect the inside interface of the ASA to the router?
This should be connected through outside to the router as the router is connected to the outside world otherwise what is the use of the firewall?
What is connected to outside then? as I see you receive an IP address on outside from a DHCP server along with a default route ? Where are the other devices connected to?
Regards.
Alain
Thanks for getting back to me. the DHCP address asigned to the outside interface is from the ISP. The ASA is connected directly to a cable modem.
The speedtouch connecting the 192.168.11.0 network to the 192.168.14.0 network is in a differnet buidling (Where the cable modem come ine) that can only be accessed via the local network/inside interface (fibre connect buildings and my switches will not VLAN). Maybe I haven't given the best description of what I'm trying to achieve.
I'd like for all traffic sent to 192.168.11.254 (the ASA) sent to the 192.168.14.0 network to be routed through the Speedtouch's (192.168.11.253) existing VPN connection. This VPN is definitley working and I can create static routes to this network from other devices (a Draytek router). However, I cannot get ASA to communicate with it.
Is there a differnet way I shoudl be setting the static route up?
Hope that makes sense. Please let me know if you need any further information.
Many Thanks .
462
