03-14-2014 10:50 AM - edited 03-04-2019 10:35 PM
Not sure what is going on here. I have several routers conected via MetroE cloud.
R1
router ospf 100
router-id 10.10.99.1
auto-cost reference-bandwidth 100000
network 10.6.237.0 0.0.0.15 area 0
network 10.10.0.0 0.0.0.255 area 1010
network 10.10.1.0 0.0.0.255 area 1010
network 10.10.2.0 0.0.0.255 area 1010
network 192.168.253.0 0.0.0.255 area 1010
ip route 10.10.0.0 255.255.255.0 10.10.2.1
ip route 10.10.1.0 255.255.255.0 10.10.2.1
ip route 10.10.2.0 255.255.255.0 10.10.2.1
ip route 192.168.253.0 255.255.255.0 Null0 *** for testing***
R2
router ospf 200 |
router-id 10.3.1.129 |
auto-cost reference-bandwidth 100000 |
area 0 range 10.3.0.0 255.255.0.0 |
summary-address 10.3.0.0 255.255.0.0 |
summary-address 10.102.133.0 255.255.255.0 |
network 10.3.1.129 0.0.0.0 area 0 |
network 10.6.237.0 0.0.0.15 area 0 |
network 10.96.0.0 0.0.0.255 area 0 |
They can see each other when I do a show ip ospf neighbor
Both routers can see OSPF routes from other routers, but I can not see any of the subnets from R1,,
Thanks!!!
Ray
Solved! Go to Solution.
03-14-2014 11:32 AM
Ray
do you mean the above routes are not seen ?
If so using network statements for these routes under OSPF won't advertise static routes.
The "network ..." statement under your OSPF configuration tells OSPF which interfaces to start on. Once it starts on that interface the network would be advertised but if you have no interfaces on your router for those networks then it won't.
This is common to all IGPs but not BGP where the "network .." statement is actually used to tell BGP which networks to advertise.
So do you have interfaces in the router that have IPs from those subnets ?
If you don't then on your router you need to make these changes -
1) remove the "network ..." entries
2) under your router OSPF configuration -
redistribute static subnets
ie. you are redistributing the static routes you have configured into OSPF.
Couple of things -
1) only remove the statements if you don't have any interfaces in that range. So from the looks of it you would still need the "network 10.6.237.0 0.0.0.15 area 0" line
2) if you have other static routes you don't want advertised you will need to use a route map with the redistribute command to filter which routes you want redistributed.
If you do have interfaces with IPs from those subnets can you clarify why you have configured static routes ?
Jon
03-14-2014 11:32 AM
Ray
Couple of things -
Jon
03-17-2014 05:43 PM
That was it!!! Thanks so much. It's always the little stuff that bites you at the end. Went ahead a put together an extensive route-map to control the distribution, all good here
Thanks again!!!
Ray
