11-05-2010 09:04 AM - edited 03-04-2019 10:23 AM
We have two Nexus 5010 to test the solution. As part of the testing we upgraded the boxes from 4.2.1.N1.1 to 5.0.2.N1.1 and after the reboot the switch lost all of the VLANs. We put the VLANs back and when we got to the private VLANs we got the following error:
%PRIVATE_VLAN-2-PVLAN_ASSOC_UP_FAILED: Failed to bring up the association between 530 & 531
Did anyone have anything like that?
11-05-2010 12:05 PM
During test phase, your local Cisco SE should be in charge of all the necessary pre-sales technical support.
03-22-2012 03:50 AM
Hello Balla,
Regarding this old post, I am just wondering if you get a chance to bring back the pvlan association UP ? If yes what did performed on your side.
I am indeed experiencing a similar issue with this error message.
Thanks a lot.
Karim
03-22-2012 04:43 AM
Hi Karim,
I had to associate the private VLANs again and it worked. My biggest concern was that during the upgrade I lost all of the VLAN configurations. When I opened a case about it I got the usual message, it is a bug. It turned out the under version 4.X the VLANs are created and stored differently than under version 5.X and there was nothing in place to convert the VLANs from the 4.X version to 5.X version.
03-22-2012 06:43 AM
Many thanks Balla for your feedback and the informations provided.
Best regards.
Karim
