Community Member
NM-16ESW configuration
I have 02 MPLS link form different ISPs, both are providing ethernet ports, I have 2811 router with 2FE ports.Both ISP links will terminate on these FE ports.
Now i need 01 port for LAN connectivity and want 01 port additionally, so that i can use it if FE0/0 or FE 0/1 fails for MPLS link termination.
For this I want to use NM-16ESW.
Routing protocols are OSPF,BGP
I can configure switch port as routed port by giving "No Switchport" command and can assign IP Address natively to this interface,But will this work in my scenario ?
Please advise .
Vijay Sharma
Silver
Re: NM-16ESW configuration
Hi Vijay,
yes, this will work for you. You can use the Ether switch ports as the L3 ports and this will work for you.
HTH, Please rate if it does.
-amit singh
191
