NM-1CE1B in 2800 chassis?
Does anyone know for sure whether the older NM-1CE1B ISDN primary rate works in a 2800 series chassis, or do I have to update to a NM-1CE1T1-PRI?
Conversely, does the newer NM-1CE1T1-PRI work in the 2600 series chassis?
Kevin Dorrell
Luxembourg
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Silver
Re: NM-1CE1B in 2800 chassis?
Hi Kevin
According to table 3 in this document:
http://www.cisco.com/en/US/products/ps5854/products_qanda_item0900aecd80169bd6.shtml
NM-1CE1B is not supported in 2800 series
Anyone?
I found half an answer to my second question: yes an NM-1CE1T1-PRI does work in a 2600XM chassis. http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf page 120. However, it does not tell me if it works in the non-XM chassis.
I stil do not know if the MN-1CE1B works in a 2800 chassis. Anyone?
Kevin Dorrell
Luxembourg
Silver
Hi Kevin
Thanks, that is exactly what I needed. In fact, that is a very useful altogether.
Kevin Dorrell
Luxembourg
566
