01-29-2009 09:07 AM - edited 03-04-2019 01:02 AM
I have read that chanelized E1 cards like NM-1CE1T1-PRI have no built in D channels.Signaling is done inband
Can this card be used for ISDN PRI connection in a central site where the company has several branch offices having WIC-1B-U-V2 card ?
Solved! Go to Solution.
01-29-2009 09:41 AM
That is incorrect, all channelized cisco cards have full support for D-channel in all Q.931 and QSIG variants (voice).
So yes the card is indicated and will work.
01-29-2009 11:42 AM
Hi, you can have 15 remotes office with two calls each. If you never configured ISDN I suggest you hire a reputable professional to help, however it is explained in the documentation.
Do not configure channel-groups as incorrectly suggested by a poster above.
Thanks for the nice rating and good luck.
01-29-2009 09:41 AM
01-29-2009 10:09 AM
In that case what is the maximum number of remote routers that i can add?
I am having one one central office and several remote offices and the 2 Mgbs isdn link is in central office while 128KPBS isdn link is in remote office.
Can you provide sample configurations ?
01-29-2009 10:46 AM
see the only thing you have to do is create time slots like below.(this example gives 64kb in each time slot if you need more please add time slots 5-7 like this for more bandwidth)
channel-group 1 timeslots 1
channel-group 2 timeslots 2
channel-group 3 timeslots 3
channel-group 4 timeslots 4
then automatically serial interfaces will be created.assign ip addresses to each of these logical interfaces.
hope you have LL at remote branches.
pls rate if it helps
Binoy
01-29-2009 10:47 AM
Binoy
01-29-2009 10:47 AM
Binoy
01-29-2009 11:42 AM
