Webcast-Catalyst9k
NM-1VSAT-GILAT
dear all,
is there any way to break password for NM-1VSAT-GILAT ?
regds,
aman
1 REPLY
Silver
Re: NM-1VSAT-GILAT
Do you mean the password provided by the VSAT service provider ? Although I did not try to configure this interface, and I believe you cannot show the password even you can access the router. The password is provided by the VSAT provider, so you have no way to get it outside the provider ..
Could you clarify the problem ?
Check below for more info.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00806b5f2b.html
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_module_installation_guide_chapter09186a00802ea0c5.html
Hope this helps.
121
