NM-8AM-V2 modem firmware upgrade
Question:
I am using a NM-8AM-V2 module on a cisco2811. To ugrade the modem firmware, I need to upgrade the IOS.
Can I upgrade only the modem firmware with a separate microcode ?
If yes, where can I find recent microcodes ?
On the CCO I only found old modem MCOM microcodes.
1 REPLY
Re: NM-8AM-V2 modem firmware upgrade
The portware is loaded upon startup of the IOS. Mica modem software is rarely updated on CCO. If you require a upgrade, copy the new mica modem portware to flash, The router should automatically load the latest mica firmware found in flash upon reloading
When copying the mica software to flash, ensure you have sufficient space do not erase flash
107
