NM-8CE1T1-PRI= ???
How many NM-8CE1T1-PRI= can I put into 3745 router given this link http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet0900aecd80710c88.html it's one so can anyone confirm this for me?
Re: NM-8CE1T1-PRI= ???
That's right, its just the one in the 3745.
That gives you basically 184 ISDN B channels or DS0s, which is quite a bit for that router.
NS
Many Thanks, one question is it better to go for the NM-8CE1T1-PRI with 128 channels or 4x of NM-2CE1T1-PRI with 128 each?
Hall of Fame Super Gold
Note, the NM-8CE1T1-PRI is supported only on the 3800 series router, and not on the 3700. So you will have to use the other solution for the 3700.
281
