NM-HDV-2 Crash
I have a 2621 router that has a NM-HDV-2 module in it. Every couple of hours, the below message comes across the terminal and all routing stops on the router. I have to reset the router to get anything to happen. Of course, if I leave the module unplugged, the router performs flawlessly. Is it a bad module or something I don't have configured correctly? Any help is appreciated. Thanks.
*Mar  1 02:04:15.683: HDV Crash info Slot 1
CPU Register Context:
PC  = 0x000054A8  MSR = 0x00001002  CR  = 0x33000000  LR    = 0x00005458
CTR = 0x00007ABC  XER = 0xC000057F  DAR = 0x0007FFDC  DSISR = 0x00000801
DEC = 0x00000000  TBU = 0x00000000  TBL = 0x00000000  IMMR  = 0x00F02100
R0  = 0x00005458  R1  = 0x0007FFD0  R2  = 0x000190F8  R3    = 0x00000200
R4  = 0x00032BAC  R5  = 0x00038DCC  R6  = 0x000385E8  R7    = 0x00038DCC
R8  = 0x00039850  R9  = 0x00010000  R10 = 0x00038C28  R11   = 0x00000000
R12 = 0x00180000  R13 = 0x00019284  R14 = 0x00F00000  R15   = 0x00000040
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000400  R19   = 0x00001400
R20 = 0x00080000  R21 = 0x00000000  R22 = 0x01000000  R23   = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x04000000  R27   = 0x00000000
R28 = 0x000333BC  R29 = 0x00046550  R30 = 0x06177F6C  R31   = 0x00009002
*Mar  1 02:04:15.687: Stack trace:
PC = 0x000054A8, SP = 0x0007FFD8
Frame 00: SP = 0x0007FFD8    PC = 0x000084BC
Frame 01: SP = 0x0007FFE0    PC = 0x00009002
Frame 02: SP = 0x0007FFF8    PC = 0x00007284
Copland Status (CoplandStat_t*) 0x40846550
qmc table (qmc_table_t*)0x40839850 system (copland_system_t*)0x40800000
*Mar  1 02:04:15.687: %HDV-2-FATAL_ERROR: HDV in slot 1: An unrecoverable error occurred.
Green
NM-HDV-2 Crash
This is the output from the error decoder
Showing 1-2 of 2 resultsPage:
1.%HDV-2-FATAL_ERROR: HDV in slot [dec]: An unrecoverable error occurred.
The HDV card has experienced an internal unrecoverable error. This error can be caused by an internal firmware error or defective HDV hardware.
Recommended Action:Power down, reinsert the network module, and reboot the router. If this message recurs, copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
Related documents- No specific documents apply to this error message.
2.
%HDV-2-FATAL_ERROR:
The HDV card experienced an internal unrecoverable error. This may be due to a internal firmware error or bad HDV hardware.
Recommended Action:Power down, reinsert the network module and reboot. If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at
http://tools.cisco.com/ServiceRequestTool/create/http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
I would try upgrading the IOS to the latest that your memory capacity DRAM/FLASH can support
Reboot and monitor
If the failure still exists try swapping the card if you can
Alex
Please rate useful posts.
Regards, Alex. Please rate useful posts.
NM-HDV-2 Crash
This is the current IOS I am running. Any known issues with that card and this IOS? I am going to see if I can get a higher version. I got this router from Ebay and obviously don't have a support contract for it.
c2600-is-mz.123-22.bin
Green
NM-HDV-2 Crash
Your IOS has been dropped by Cisco - no reason given
The nearest downloadable version is
c2600-is-mz.123-22a.bin
Alex
257
