NM-HDV compatable w/WIC1DSUT1
i have a 3745 with a nm-hdv network module installed. the nm-hdv module currently has a vwic1mft-t1 which died last week and i want to replace the vwic1mft-t1 with vwic1dsu-t1. are they compatable?
thanks in advance.
Silver
Re: NM-HDV compatable w/WIC1DSUT1
I think you meant to ask that you wanted to replace it with a WIC-1DSU-T1 and not VWIC-1DSU-T1?
As far as I know the NM-HDV can only support VWICs and does not support a WIC. Usually you use the NM-HDV combined with a VWIC-MFT to support voice applications; the NM-HDV provides the DSP resources. If you were indeed supporting voice services on the VWIC (which you most probably were considering the fact that it was installed in a NM-HDV) you will not be able to support them by replacing it with a WIC-1DSU-T1. Moreover a WIC-1DSU-T1 will not work with a NM-HDV (AFAIK).
your right - i do need to support voice but didnt think to consider that when i looked at the card.
i really appreciate your input.
thanks.
91
