No able to ping peer ip address
Dear Friends,
We are having a STM1 - 155 Mbps link to our provider.
Now I am able to extended ping but not standard ping .
Atul
Re: No able to ping peer ip address
More info is required....what parameters are you changing in the extended ping to make it work? What do the configs for each side of the link look like?
KUIX_2#ping www.yahoo.com
Translating "www.yahoo.com"...domain server (82.145.192.66) [OK]
Sending 5, 100-byte ICMP Echos to 216.109.118.77, timeout is 2 seconds:
Success rate is 0 percent (0/5)
KUIX_2#ping
Protocol [ip]:
Target IP address: www.yahoo.com
Repeat count [5]: 10
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 62.216.146.145
% Invalid source
Source address or interface: 62.216.146.146
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 10, 100-byte ICMP Echos to 216.109.118.77, timeout is 2 seconds:
Success rate is 100 percent (10/10), round-trip min/avg/max = 280/280/284 ms
KUIX_2#
Silver
Is it possible to show the route for yahoo.com and the config on the router if possible.
106
