No DHCP and no mannual config?
pratik16nov891
If a device wants to communicate with another device, and if there is no DHCP server in the network and if the manual configuration of the address is not possible, how will the two devices on the same link communicate?
2 Accepted Solutions
ghostinthenet
Level 7
Level 7
For IPv4, many DHCP-enabled devices will auto-configure a 169.254.0.0/16 address when they can't get a DHCP lease. This is enough for them to have basic connectivity on a single subnet for peer-to-peer networking.
For IPv6, all devices will auto-configure an fe80::/16 link-local address which will allow for basic connectivity on the same subnet regardless of whether DHCP is enabled or not. If IPv6 is enabled at all, this option will be available.
I'm happy to hear that. If you found our comments useful, please rate them and mark one of them correct.
14 Replies 14
Ven Taylor
Level 4
Level 4
It depends on the device.  PCs will use other broadcast-based applications like NETBIOS.
Switches and routers will use CDP to at least discover one another.
Sounds like this would be a pretty rare situation.  What do you have going on?
Ven Taylor
Thank you for the reply..!!
It was helpful
ghostinthenet
Level 7
Level 7
Thank you...!!
It was helpful
Can you help me with one doubt i have, i am designing a network for a organization in packet tracer (for practice). It has 3 locations and each office should have 200 employees with 65% redundancy (For IP address)....i am confused with 65% redundancy term...is this means we need to use CARP protocol...
CARP, VRRP and HSRP provide redundancy for individual hosts and gateways, but there's really no concept of a percentage in that. At a guess, I would suggest that it's asking for 65% expansion room on the subnets, so 200*1.65=330 node addresses, but it's hard to tell from the description that you've been given.
I have two departments HR and finance in my office, the finance department (170.10.1.0/24) can access HR (170.10.0.128/25) but the HR cannot access Finance. I have DHCP server (170.10.0.129/28) in HR department for assigning ip to both departments.
I have used two access list
1) one on the inteface facing Finance department as
  permit udp host 0.0.0.0 host 255.255.255.255 eq bootps
  deny ip any any
2) I have used following access list on the interface which facing to HR department as
    permit icmp any any echo-reply
    permit icmp any any unreachable
Now i am stuck with the issue that DHCP server is not assigning the ip address to Finance department
could you suggest me what should i add in the access list at the HR interface so that the udp packet (DHCP offer) from server can cross the network to Finance.
i have tried
permit udp host 170.10.0.129 host 255.255.255.255
it is not working...can you suggest how to get this done
For this, you're going to need to make sure your inbound ACLs on both interfaces are agreeing with each other. You're also going to need to make them less specific.
On the inbound ACL facing the Finance network, try this:
permit udp any any eq bootps
On the inbound ACL facing the HR network, go with this:
permit udp any eq bootps any
After that, because DHCP doesn't cross subnets on its own, you're going to need to configure a helper address on the Finance interface in order to forward DHCP requests to the server.
ip helper-address x.x.x.x
Substitute x.x.x.x with the address of your DHCP server.
Thank you..!!
Do HSRP work on vlan?
i have made a topology and in which i have 3 Vlan and i am not able to ping the virtual ip address from any of the hosts in any vlan's.
Is the configuration for vlan some different than n/w without vlan
HSRP works on VLAN interfaces and is very commonly used. Its configuration isn't any different than it is on non-VLAN interfaces.
Also do it works on subinterface of a router as an gig0/0.1?
Yes, it works on those too.
Ok,
I have two vlans, vlan 100 (170.10.0.0/25) and vlan 200 (170.10.0.128/25)
Vlan 100 is connected to router in interface gig0/0.1 and Vlan 200 is connected to router on interface gig0/0.2
Now consider only for vlan 100
i have a host with ip 170.10.0.1/25 and i have used a virutual ip as 170.10.0.100 and configured both the HSRP routers as
Router1(config)#int gigabitEthernet 0/0.1
Router1(config-subif)#standby 1 ip 170.10.0.100
Router1(config-subif)#standby 1 priority 200
Router1(config-subif)#standby 1 preempt
Router1(config-subif)#exit
 %HSRP-6-STATECHANGE: GigabitEthernet0/0.1 Grp 1 state Standby -> Active
Router1(config-subif)#standby 1 track gigabitEthernet 0/1
Router2(config)#int gigabitEthernet 0/0.1
Router2(config-subif)#standby 1 ip 170.10.0.100
Router2(config-subif)#standby 1 priority 210
Router2(config-subif)#standby 1 preempt
Router2(config-subif)#exit
Router2(config-subif)#standby 1 track gigabitEthernet 0/1
Now when i try to ping the virtual ip from my host 170.10.0.1, it gives me request time out.
Are my config right?
