03-14-2009 01:26 AM - edited 03-04-2019 03:55 AM
Hope someone can help? I upgraded my ios from c870-advipservicesk9-mz.124-15.T8.bin to c870-advipservicesk9-mz.124-22.T1.bin, as per the software advisor. When I reload the router I am unable to get an IP address from my ISP, if I go back to 124-15T8 everything works great. Does anyone have any ideas.
Thank you in advance.
03-14-2009 05:38 AM
Possible software defect introduced in the later code. (Many enhancements added to 12.4.20T and 12.4.22T.) If you have maintenance, contact TAC. (If you don't need a later feature, you could also stay with 12.4.15T#.)
PS:
You might also try 12.4.24T.
03-14-2009 04:00 PM
Thank you for your reply, I do have a smartnet on this router. I will try the 12.4.24t and if that does not work I will call TAC.
Thanks again for your reply.
