01-04-2006 07:39 AM - edited 03-03-2019 11:21 AM
The command
"no ip mroute-cache"
is added by default on my router config.
What does it do exactly?
01-04-2006 07:51 AM
It disables fast switching of multicast packet on the interface on the Cisco router. Check
If you are not routing multicast packets (which is also the default) , it is insignificant.
01-04-2006 07:53 AM
generally "mroute" refers to IP multicast.
So it basically does deactivate fast-switching for multicast traffic.
Have a look at
Hope this helps
Martin
