Community Member
No translation group found
Hi All ,
I am getting an error in ASA. I couldn't able to reach outside world. Shown here my log error messages.
Thanks in advance
3|Feb 20 2008|16:42:36|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:35|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:34|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:33|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:32|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:31|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:30|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:29|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:28|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
3|Feb 20 2008|16:42:27|305005|4.2.2.2||No translation group found for icmp src fugen-dmz:172.16.1.253 dst outside:4.2.2.2 (type 8, code 0)
Community Member
Re: No translation group found
hi
could you show any NAT and acl configuration?
Community Member
thanks for your reply...
access-list 200 standard permit 192.168.0.0 255.255.0.0
access-list 200 standard permit 172.31.0.0 255.255.0.0
access-list 200 standard permit network161 255.255.255.0
access-list 200 standard permit network162 255.255.255.0
access-list fugendmz extended permit icmp any any echo-reply
access-list fugendmz extended permit ip any any
access-list 111 extended permit ip 192.168.49.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list 111 extended permit ip 172.31.0.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list 111 extended permit ip any 10.100.100.0 255.255.255.0
access-list 111 extended permit ip network161 255.255.255.0 192.168.50.0 255.255.255.0
access-list 111 extended permit ip network162 255.255.255.0 192.168.50.0 255.255.255.0
access-list 112 extended permit ip 192.168.48.0 255.255.255.0 192.168.50.0 255.255.255.0
access-list 201 standard permit 192.168.101.0 255.255.255.0
access-list 202 standard permit 192.168.49.0 255.255.255.0
access-list 202 standard permit 192.168.101.0 255.255.255.0
access-list 203 standard permit 192.168.49.0 255.255.255.0
access-list internal_access_out extended permit udp 192.168.48.0 255.255.255.0 eq ntp 63.146.69.168 255.255.255.248 eq ntp
access-list fgdev extended permit ip any host 172.31.0.1
access-list fugen-dmz extended permit ip any 63.146.69.168 255.255.255.248
access-list 161 standard permit network161 255.255.255.0
access-list 162 standard permit network162 255.255.255.0
access-list split standard permit network161 255.255.255.0
access-list split standard permit network162 255.255.255.0
access-list fg-idsys extended permit ip any any
access-list fg-idsys extended permit icmp any any echo-reply
access-list fg-idsys extended permit ip any 63.146.69.168 255.255.255.248
ip local pool fugen 192.168.50.1-192.168.50.254 mask 255.255.255.0
ip local pool cisco 10.100.100.1-10.100.100.100 mask 255.255.255.0
icmp permit any fugen-dmz
nat-control
global (outside) 1 interface
global (fugen-dmz) 1 interface
global (fg-idsys) 1 interface
nat (internal) 0 access-list 112
nat (internal) 1 192.168.48.0 255.255.255.0
nat (fugen-dmz) 0 access-list 111
nat (fugen-dmz) 1 192.168.49.0 255.255.255.0
nat (fugen-dmz) 1 192.168.100.0 255.255.255.0
nat (fugen-dmz) 1 192.168.101.0 255.255.255.0
nat (fugen-dmz) 1 172.16.0.0 255.255.0.0
nat (fugen-dmz) 1 172.31.0.0 255.255.0.0
nat (fg-idsys) 1 network161 255.255.255.0
nat (fg-idsys) 1 network162 255.255.255.0
alias (fugen-dmz) 192.168.101.155 200.198.184.106 255.255.255.255
static (fugen-dmz,outside) 63.146.69.171 192.168.49.10 netmask 255.255.255.255 dns
static (fugen-dmz,outside) 63.146.69.173 172.31.0.154 netmask 255.255.255.255
static (fugen-dmz,outside) 63.146.69.174 192.168.49.13 netmask 255.255.255.255
access-group inbound in interface outside
access-group internal_access_out out interface internal
route outside 0.0.0.0 0.0.0.0 63.146.69.169 1
route fg-idsys network161 255.255.255.0 192.168.70.1 1
route fg-idsys network162 255.255.255.0 192.168.70.1 1
route fugen-dmz 172.31.0.0 255.255.0.0 192.168.254.1 1
route fugen-dmz 192.168.49.0 255.255.255.0 192.168.254.1 1
route fugen-dmz 192.168.100.0 255.255.255.0 192.168.254.1 1
route fugen-dmz 192.168.101.0 255.255.255.0 192.168.254.1 1
189
