Community Member
Not able to classify traffic on output to MPLS
Have a scenario with hairpin between two VRFs on PE router
Sending traffic to PE from MPLS network via one vrf and sending it back via second vrf.
Everything works, traffic flows. (Theres no CE in this moment, or I do not need it now)
I am not able to classify traffic based on DSCP, IP addressess, anything on OUTPUT back to MPLS.
Basically what I would need, I would need to set COS on output back to MPLS so I could test
the providers line, whether it transports all cos numbers.
Could anyone give me any hint?
Thaaaaaank you :-)
Leo
Everyone's tags (3)
Hall of Fame Super Silver
Re: Not able to classify traffic on output to MPLS
Hello Leo,
are you doing true L3 VPN MPLS?  or VRF lite?
if you are doing L3 VPN MPLS the outgoing packets are encapsulated within MPLS frames so you should classify traffic based on EXP bits of MPLS header not on inner fields of payload.
match mpls exp  instead of match ip precedence in class maps definition
Be aware that by default EXP bits contain a copy of IP Prec bits of transported IPv4 packet.
What device are you using as PE router ? What IOS image is running on it?
Hope to help
Giuseppe
Community Member
This is true MPLS L3 VPN
PE router is ASR 1006
well, with those EXP bits...
the traffic comes from MPLS core network into lets say vrf PGUP
than it goes via gre tunnel (hairpin) into another vrf PGDN
so it comes to vrf PGDN as if it came from a regular CE...if I understand it correctly.
and it goes back somewhere into MPLS network and I need to set cos on it.
but since it came from gre tunnel it doesnt have any labels on it and I cant match on EXP bits.
AND...match access-group, or match dscp doesnt work...
think it might work somehow?
Leo
PS: and thanks for replying of course
Hello Leo,
please provide a network diagram your setup is quite complex
Hope to help
Giuseppe
355
