Not able to configure "dual-active detection bfd" in Cisco 6500 VSS switch
                   Dear Team,
i am not able to configure the command dual-active detection bfd in cisco 6500 VSS switch.
Trying to configure the bfd between two switches having a direct connectivity between two switches physically by an gig int. ...
Here is the attempt given below,
PDC2-S4-VSS-C6506#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
PDC2-S4-VSS-C6506(config)#switch virtual domain 100
PDC2-S4-VSS-C6506(config-vs-domain)#dual
PDC2-S4-VSS-C6506(config-vs-domain)#dual-active ?
  detection  Dual-active detection enable
  exclude    Dual-active cmd to exclude interface from shutdown in recovery
             mode
PDC2-S4-VSS-C6506(config-vs-domain)#dual-active detection ?
  fast-hello  Dual-active detection fast-hello enable
  pagp        Dual-active detection pagp enable
PDC2-S4-VSS-C6506(config-vs-domain)#exit
*****************************sh version***************************
sh version
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.0(1)SY4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 18-Mar-13 00:26 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
PDC2-S4-VSS-C6506 uptime is 3 days, 21 hours, 14 minutes
Uptime for this control processor is 3 days, 21 hours, 16 minutes
System returned to ROM by reload at 10:20:11 UTC Mon Oct 28 2013
System image file is "bootdisk:s2t54-ipservicesk9-mz.SPA.150-1.SY4.bin"
Last reload reason: Conversion
--More--                           to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (M8572) processor (revision ) with 1769472K/262144K bytes of memory.
Processor board ID SAL17299VXT
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from s/w reset
6 Virtual Ethernet interfaces
294 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
--More--                           Configuration register is 0x2102
Kindly assist for why i am not able to to configure the command.........
  • WAN Routing and Switching
122
