Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
NTP question
I would like for my 4507 to be the ntp server for my LAN. It looks like I have to configure the NTP broadcast on a specific interface. So how does that work for the rest of the network or do I have to configure it on every single one of my interfaces?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: NTP question
b.rockburn wrote:
I just want our servers domain controllers and the like to use the core as the ntp server. So configuring the core as an ntp master is the key?
Brent
Yes, but there can be compatability issues between Windows and Cisco, you may need to just test and see what happens. At my last place we had a dedicated time server that we peered a Cisco router to and then peered all our Cisco devices to that router and the Windows guys peered directly with the dedicated time server.
Also are you intending to sync the master 4500 with an internet time server or are you more concerned with just syncing devices to the same time with your LAN ?
Jon
Re: NTP question
b.rockburn wrote:
My 4507 is already synched with external ntp sources.
Brent
Great, then you should be all set.
Jon
Re: NTP question
Brent
You don't need to configure it to broadcast unless you want to ie. standard way is to -
on the 4507 configure it as an "ntp master" and then on each switch/router configure it as "ntp client "
The ip address can be a loopback or any interface address as long as it is advertised by your routing protocol.
Or did you specifically want to use broadcast ?
Jon
Re: NTP question
Re: NTP question
Brent
Jon
Re: NTP question
Re: NTP question
Brent
Jon
Re: NTP question
Brent
Thanks for the ratings but i made a slight error. ntp master is used when there is no external server to sync up with. If you are already syncing to an external device you will have ntp peer commands on your 4507. So you should be able to point other devices to your 4507 already without having to add any other commands on your 4507.
Apologies for that, been a long day
Jon
233
