Webcast- Automate Nexus9k
Highlighted
Community Member
number of static NAT statements upper limit??
I'm configuring an 1801 and need to set up static NAT to allow external access to inside devices.
I've configured the following statement using specific tcp port numbers;
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 1xx.1xx.x.x 443 2x.5x.xxx.xx 443 extendable
everything works well....my question is.....is there an upper limit to the number of static NAT mappings I can configure??
...thanks in advance........Jamie
1 REPLY
Community Member
Re: number of static NAT statements upper limit??
I don't know however I would imagine that
the only limit is the amount of configuraiton
memory that you have. You could move the config to flash then you would have more:-) Eventually you
would of course run out of memory.
It has been rumoured, but I don't see why it
might be the case, that performance decreases
with NAT table size.
It is possible to limit the number of NAT
translations. Tha max limit value is 4G.
i.e. 2 ^ 32. By default it is not limited.
Try it out time.
Would be easy to use a spreadsheet to
fake up a big config. Cut/paste/crash:-)
127
