NVRAM Error...
I'm Getting Error in router from NVRAM while accessing below command in privilge 6 login.
RT01#show startup-config
Using 7328 out of 262136 bytes
%Error opening nvram:/startup-config (Permission denied)
RT01#
The error not observed while executing the command through privilege 6 login.
Plese help on this.
  • WAN Routing and Switching
Hall of Fame Super Silver
NVRAM Error...
The error itself seems fairly straightforward - the person attempting to execute the command does not have sufficient permissions to execute that command.
I find your description of the problem to be confusing. At the beginning you say " I'm Getting Error in router from NVRAM while accessing below command in privilge 6 login" and later you say "The error not observed while executing the command through privilege 6 login". The second statement contradicts the first. Can you provide clarification?
Rick
NVRAM Error...
HI Richard,
Thanks for your reply,
when giving this command show startup-config from privilge 6 login I was getting this error.
RT01#
and in router i was allowed the access of this show startup-config command in privilge 6 login.
command is
privileage exec level 6 show startup-config
But still I am getting the Error message Permission denied.
please let me know if you want more details on this.
Jitesh Mahajan.
470
