Community Member
Object Tracking EVDO and then dial?
I want to see a config if anyone has one that can track a primary path and fail over to secondary path and if secondary path is down fail over to dial backup. The routing is tricky and I cannot figure it out. Anyone done this yet?
I have configs that do both well (primary to secondary (EVDO) and Primary to dial backup) but I need to combine. Anyone do an sla tracking another sla?
1 REPLY
Community Member
Re: Object Tracking EVDO and then dial?
hi jerry,
interface serial 0
ip address 172.16.162.2 255.255.255.0
no shut
interface serial 1
ip address 10.16.162.2 255.255.255.0
no shut
int bri 0
ip address negotiated
encapsulation ppp
dialer idle-timeout 300
dialer string xxxxxxx
dialer-group 1
isdn switch-type basic-net3
priority-group 1
ppp pap sent-username xxxxx password xxxxx
ip route 198.16.162.0 255.255.255.0 172.16.162.1 (primary)
ip route 198.16.162.0 255.255.255.0 10.16.162.1 50 (secondary -floating)
ip route 198.16.162.0 255.255.255.0 bri 0 100 (bri - floting)
will this work ?
Rajeev.S
113
