Webcast-Catalyst9k
OER BR ACTIVE PROBE Parent route not found?
Hello Everybody,
I have an issue with my PFR SOlution
I Have 2 Router :
one is the MC/BR and the second router is the BR
My MC/BR have 2 external Link and my second BR have one external Link
***** LOAD SHARING CONFIG ON THE MC/BR ******
ip nat inside source route-map ISP_Secondary interface GigabitEthernet0/1.210 overload
ip nat inside source route-map ISP_Terciary interface GigabitEthernet0/1.213 overload
route-map ISP_Secondary permit 10
match ip address INSIDE_ADDRESS
match interface GigabitEthernet0/1.210
route-map ISP_primary permit 10
match interface GigabitEthernet0/1.211
*********************  INTERFACE CONFIG INTERNAL AND EXTERNAL *************************
interface GigabitEthernet0/0
description LINK TO LAN
ip address 10.30.21.1 255.255.255.248
ip nbar protocol-discovery
ip flow monitor MYMONITOR input
ip nat inside
ip virtual-reassembly in
standby 0 timers 2 4
standby 10 ip 10.30.21.6
standby 10 priority 150
standby 10 preempt
standby 10 name HSRPGRPE1
standby 10 track 10 decrement 100
duplex auto
speed auto
service-policy input QOS-MARKING1
description TRUNK *** BLOCK EDGE LAYER ****
no ip address
load-interval 30
duplex auto
speed auto
description LINK ISP1
bandwidth 10000
encapsulation dot1Q 211
ip address 105.174.0.10 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
description LINK ISP2
bandwidth 1000
encapsulation dot1Q 213
ip address 41.223.40.10 255.255.240.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
************************************* ROUTING CONFIG **************************************************************
Here is the routing Config for the MC/BR
ip route 0.0.0.0 0.0.0.0 105.174.0.9 5 name GATEWAY-UNITEL track 10
ip route 0.0.0.0 0.0.0.0 41.223.40.1 10 name GATEWAY_ACS
Here is the Config routing for the BGP between the 2 router ( MC/BC and BC2)
router bgp 65510
bgp router-id 3.1.1.1
bgp log-neighbor-changes
neighbor 10.30.21.3 remote-as 65510
neighbor 10.30.21.3 update-source GigabitEthernet0/0
neighbor 10.30.21.3 next-hop-self
****************************************** PFR CONFIG ********************************************************
Here is the PFR CONFIG
pfr master
policy-rules WEB_SHARING
max-range-utilization percent 10
keepalive 10
border 3.1.1.1 key-chain PFRBORDER
  interface GigabitEthernet0/1.213 external
   link-group ACS
  interface GigabitEthernet0/1.211 external
   max-xmit-utilization percentage 90
   link-group Unitel
  interface GigabitEthernet0/0 internal
border 10.30.21.3 key-chain PFRBORDER
  interface Tunnel10 external
   link-group DMVPN1
  interface FastEthernet0/1.212 external
   link-group ITA
  interface FastEthernet0/0 internal
learn
  throughput
  delay
  periodic-interval 0
  monitor-period 1
  list seq 5 refname LoadSharing-web
   traffic-class access-list MEDIUM_PRIORITY_DATA
   count 50 max 90
   throughput
  list seq 6 refname LoadSharing_Mail
   traffic-class access-list HIGH-PRIORITY-DATA
   delay
  list seq 7 refname LoadSharing_VPN
   traffic-class access-list ANY->VPN filter PRIVATE_NETWORKS
   aggregation-type prefix-length 16
   throughput
mode monitor passive
mode select-exit best
resolve delay priority 1 variance 20
resolve utilization priority 5 variance 20
resolve range priority 9
pfr border
local Loopback0
master 3.1.1.1 key-chain PFRBORDER
pfr-map WEB_SHARING 10
match pfr learn list LoadSharing-web
set mode monitor passive
set link-group ACS fallback Unitel
pfr-map WEB_SHARING 11
match pfr learn list LoadSharing_Mail
set mode monitor fast
set link-group ACS fallback ITA
pfr-map WEB_SHARING 12
match pfr learn list LoadSharing_VPN
***************** Access list for PFR     *********
ip access-list extended HIGH-PRIORITY-DATA
remark *** MATCH QOS CS2 mail + exchange ***
permit ip any any dscp cs2
remark *** gmail port and others mails traffic ***
permit tcp any any eq 465
permit tcp any any eq 995
permit tcp any any eq 993
permit tcp any any eq 587
permit tcp any any eq smtp
permit tcp any any eq pop3
ip access-list extended MEDIUM_PRIORITY_DATA
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq ftp
permit udp any any eq domain
Here is the Error when i debug from the Master PFR
OER BR ACTIVE PROBE: Parent route not found
     probeType = echo, probeTarget = 173.194.67.108, probeTargetPort = 0
     probeSource = 41.223.40.10, probeSourcePort = 0, probeNextHop = Default
     probeIfIndex = 12, SAA index = 732886180 probeToS = 0 policy_seq = 0
     probeType = echo, probeTarget = 173.194.67.109, probeTargetPort = 0
     probeIfIndex = 12, SAA index = 12 probeToS = 0 policy_seq = 0
The realy question, is the the 2 default route are active and have diffirent metric ( so normally it should consider one route as a Parent route snd the other route as the secondary, so i don´t understand why have this issue ?)
Track 10
  IP SLA 10 reachability
  Reachability is Up
    4280 changes, last change 00:40:15
  Latest operation return code: OK
  Latest RTT (millisecs) 164
  Tracked by:
    STATIC-IP-ROUTING 0
RTMC_BORDER1#sh ip rou
RTMC_BORDER1#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 105.174.0.9 to network 0.0.0.0
S*    0.0.0.0/0 [5/0] via 105.174.0.9
137
