08-09-2013 04:49 PM - edited 03-04-2019 08:43 PM
Hi Guys
I have internet with to ISP provider
The First has ISP has 150 Mbps (1:1) and the other has 70Mbps (1:1)
I want know if you could have a link (or some template) of configuration where use OER, when from my LAN network is leave 60 Mbps, 40Mbps leave for the First Router (150Mbps) and the remainder 20Mbps leave for the other Routers (70Mbps). The Idea is to use Load balance
Also output of my network is the a Firewall,
The physical connection is:
Router 1 (ISP1-150Mbps) Router 2(ISP2-70Mbps)
My CPE Router - 1 My CPE Router - 2
Switch
Firewall
Best Regards
08-09-2013 11:07 PM
Hi Guillen,
You can achieve load balancing , out of 60Mbps traffic with 40Mbps taking primary path and 20Mbps taking secondary path. under oer master use the command max-range-utilization and define the percentage.
Example:
oer master
max-range-utilization percent 10 //Start Load balancing when exits links utilization differ more than 10%.
Please refer a document related to PFR
http://www.cisco.com/en/US/products/ps8787/products_ios_protocol_option_home.html
Sathvik
08-12-2013 09:37 AM
Thanks Sathvik!!
This link is very useful!!
