OER/Pfr load balance problem
Hi All
     ,, Actually I have problem in OER configuration .. Setup is I have single router acting as master controller and border router at same time , and this router is connected to two ISP routers .... The problem that load balancing is not hapenning even if the link utilization has exceed the configured percentage .. It still sending and revieving from one link only  ... See below configuration it might be helpful .. and thanks in advance ..
R1#sh running-config
Building configuration...
Current configuration : 2633 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
resource policy
memory-size iomem 5
ip cef
no ip domain lookup
ip sla monitor 1
type echo protocol ipIcmpEcho 10.82.56.1 source-interface Loopback0
threshold 1
frequency 5
key chain key1
key 1
  key-string oer
oer master
policy-rules cisco
max-range-utilization percent 2
border 10.99.99.99 key-chain key1
  interface FastEthernet1/0 internal
  interface Serial0/1 external
   max-xmit-utilization percentage 5
  interface Serial0/0 external
   max-xmit-utilization percentage 2
learn
  throughput
  periodic-interval 0
  monitor-period 1
  aggregation-type bgp
backoff 90 90
mode route metric bgp local-pref 222
mode select-exit best
resolve range priority 1
resolve utilization priority 2 variance 1
oer border
logging
local Loopback0
master 10.99.99.99 key-chain key1
interface Loopback0
ip address 10.99.99.99 255.255.255.255
interface Serial0/0
bandwidth 90
ip address 10.11.12.1 255.255.255.0
load-interval 30
serial restart-delay 0
no dce-terminal-timing-enable
interface Serial0/1
bandwidth 90
ip address 10.11.14.1 255.255.255.0
load-interval 30
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
ip address 10.222.32.2 255.255.255.0
ip flow ingress
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
log-adjacency-changes
redistribute bgp 650 subnets
network 10.11.12.0 0.0.0.255 area 0
network 10.11.14.0 0.0.0.255 area 0
network 10.222.32.0 0.0.0.255 area 0
router bgp 650
no synchronization
bgp log-neighbor-changes
redistribute connected
redistribute ospf 1
neighbor 10.11.12.2 remote-as 999
neighbor 10.11.14.2 remote-as 999
maximum-paths 2
no auto-summary
no ip http server
no ip http secure-server
oer-map cisco 1
set mode select-exit best
oer-map OEr 10
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R1#
Result of   #show oer master :
R1#sh oer master
OER state: ENABLED and ACTIVE
  Conn Status: SUCCESS, PORT: 3949
  Number of Border routers: 1
  Number of Exits: 2
  Number of monitored prefixes: 0 (max 5000)
  Max prefixes: total 5000 learn 2500
  Prefix count: total 0, learn 0, cfg 0
Border           Status   UP/DOWN             AuthFail
10.99.99.99      ACTIVE   UP       00:19:07          0
Global Settings:
  mode route metric static tag 5000
  trace probe delay 1000
  no logging
Default Policy Settings:
  backoff 90 90 90
  delay relative 50
  holddown 300
  periodic 0
  mode route observe
  mode monitor both
  loss relative 10
  unreachable relative 50
  resolve range priority 1 variance 0
  resolve delay priority 11 variance 20
Learn Settings:
  current state : STARTED
  time remaining in current state : 101 seconds
  throughput
  no delay
  no protocol
  monitor-period 1
  periodic-interval 0
  prefixes 100
  expire after time 720
R1#
Re: OER/Pfr load balance problem
If the logging enabled and you go over the link utilization specified percentage do you see any log saying OOP out of policy ?
In other word is the router detecting out of policy situation ?
Can you past the output of  "show oer master traffic-class" ?
See this below logs while pinging high packet size ..
*Mar  1 01:21:59.583: %OER_MC-5-NOTICE: Range OOP BR 10.99.99.99, i/f Se0/0, percent 3
*Mar  1 01:21:59.583: %OER_MC-5-NOTICE: Load OOP BR 10.99.99.99, i/f Se0/0,  load 3 policy 1
*Mar  1 01:21:59.583: %OER_MC-5-NOTICE: Exit 10.99.99.99 intf Se0/0 OOP, Tx BW 3, Rx BW 3, Tx Load 3, Rx Load 3
R1#
*Mar  1 01:22:19.851: %OER_MC-5-NOTICE: Range OOP BR 10.99.99.99, i/f Se0/0, percent 6
*Mar  1 01:22:19.855: %OER_MC-5-NOTICE: Load OOP BR 10.99.99.99, i/f Se0/0,  load 6 policy 1
*Mar  1 01:22:19.859: %OER_MC-5-NOTICE: Exit 10.99.99.99 intf Se0/0 OOP, Tx BW 6, Rx BW 6, Tx Load 6, Rx Load 6
R1#
*Mar  1 01:22:23.099: %OER_MC-5-NOTICE: Discovered Exit for prefix 10.82.51.1/32, BR 10.99.99.99, i/f Se0/0
R1#
*Mar  1 01:22:40.531: %OER_MC-5-NOTICE: Range OOP BR 10.99.99.99, i/f Se0/0, percent 6
*Mar  1 01:22:40.531: %OER_MC-5-NOTICE: Load OOP BR 10.99.99.99, i/f Se0/0,  load 6 policy 1
*Mar  1 01:22:40.531: %OER_MC-5-NOTICE: Exit 10.99.99.99 intf Se0/0 OOP, Tx BW 6, Rx BW 6, Tx Load 6, Rx Load 6
R1#
*Mar  1 01:22:57.087: %OER_BR-5-NOTICE: Prefix Learning STOPPED
*Mar  1 01:22:57.099: %OER_MC-5-NOTICE: Prefix Learning WRITING DATA
*Mar  1 01:22:57.259: %OER_MC-5-NOTICE: Prefix Learning STARTED
*Mar  1 01:22:57.471: %OER_BR-5-NOTICE: Prefix Learning STARTED
R1#
R1#
*Mar  1 01:23:26.443: %OER_MC-5-NOTICE: NO route change, Observe mode, 10.82.51.1/32, BR 10.99.99.99, i/f Se0/1, Reason Range, OOP reason Range
Note :: show oer master traffic-class is not supported in my platform .. I have below command which indicate for policy setting :
R1#sh oer master policy
  backoff 90 90 90
  delay relative 50
  holddown 300
  periodic 0
  mode route observe
  mode monitor both
  loss relative 10
oer-map cisco 1
  match ip prefix-lists:
  backoff 90 90 90
  delay relative 50
  holddown 300
  periodic 0
  mode route observe
  mode monitor both
*mode select-exit best
  loss relative 10
* Overrides Default Policy Setting
R1#
Please .. need a reply on this ..
Thank you ..
based on your Logs and config, i see that your mode route is "OBSERVE". Change it to "mode route control"
oer master
mode route control
HTH.
Thanks-
Gerard
Thank you Gerard for your reply ... I'm still facing issue that is not getting balanced .. now traffic should move from se1/1 to se1/2 .. but i don't now where is the problem .. See latest log and some modification rectified .
*Apr 20 18:36:32.367: OER MC EXIT: 10.99.99.99, intf Se1/2 INPOLICY
*Apr 20 18:36:32.371: %OER_MC-5-NOTICE: Load OOP BR 10.99.99.99, i/f Se1/1,  load 197 policy 67
*Apr 20 18:36:32.375: %OER_MC-5-NOTICE: Exit 10.99.99.99 intf Se1/1 OOP, Tx BW 197, Rx BW 196, Tx Load 96, Rx Load 95
R1#
*Apr 20 18:36:32.379: OER MC EXIT: 90 kbps should be moved from 10.99.99.99, intf Se1/1
R1#
R1#
*Apr 20 18:36:38.759: %OER_MC-5-NOTICE: Uncontrol prefix 10.82.51.1/32, Couldn't find the best exit
*Apr 20 18:36:38.763: %OER_MC-5-NOTICE: Uncontrol prefix 10.82.51.1/32, Couldn't choose exit in prefix timeout
R1#
*Apr 20 18:36:44.111: %OER_MC-5-NOTICE: Discovered Exit for prefix 10.82.51.1/32, BR 10.99.99.99, i/f Se1/1
R1#
Global Settings:
  max-range-utilization percent 40
  logging
  backoff 90 90 90
  delay relative 50
  holddown 300
  periodic 180
  mode route control
  mode monitor passive
  loss relative 10
Learn Settings:
  time remaining in current state : 87 seconds
  throughput
  delay
  no protocol
  monitor-period 1
  periodic-interval 0
  prefixes 100
key chain key1
key 1
   key-string oer
oer master
policy-rules cisco
logging
  interface FastEthernet0/0 internal
  interface Serial1/1 external
  interface Serial1/2 external
learn
  throughput
  delay
  periodic-interval 0
  monitor-period 1
backoff 90 90
mode route control
periodic 180
oer border
logging
local Loopback0
oer-map cisco 1
Try this .. you may need to learn your Inside Prefs..either manual or dynamic method.
Dynamic:
     oer master
      learn
        inside bgp
        no aggregation-type bgp
       oer-map cisco 1
      match oer learn inside
Manual:
  oer master
    policy-rule cisco
  ip prefix-list MYNET permit 4.5.6.0/24 (inside network for example)
  oer-map cisco 1
   ip address prefix-list MYNET inside
1108
