ā11-18-2011 07:25 AM - edited ā03-04-2019 02:19 PM
Hi, thanks in advance for your comments, I have one router and two lan interfaces that need to be on the same network just to provide interface redundancy in the event that one of them or the attached switch fails, besides configuring a BVI to bridge them, is there any other option to have these 2 lan interfaces on the same /24 network? I've had some issues with the BVI setup when traffic was not crossing the bridge. Thanks again.
ā11-18-2011 07:35 AM
apart from bridging I don't see how you could have 2 interfaces in same subnet except maybe in 2 VRFs.
Regards.
Alain
ā11-18-2011 09:35 AM
Which router is that? Do you have a modular slot available? As Alan mentioned BVI is the only option in this set up. I would buy another router to provide the optimum redundancy in my network and configure HSRP for an automatic failover.Another option could be to buy a 4/9 port ether switch module, configure the trunk ports down to the access switches and create SVI's on the router. I have not tried that but this should work.
Hope this helps.
ā11-18-2011 11:33 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
One possible option might be to port channel your two router interfaces.
