One side ATM one side MPLS based Point to Point G.Shdsl Modem Conf.
I am concerning about what should be done differently or additionaly when forming a topology where cisco dsl routers are used in one side connected to an ATM network and in the other to MPLS network.
Thank you.
Hall of Fame Super Silver
Re: One side ATM one side MPLS based Point to Point G.Shdsl Mode
Hello Fatih,
without more details it is difficult to say something meaningful:
you may need ipsec tunnels or not and so on.
Describe your scenario with more details to get better help
Hope to help
Giuseppe
In fact i don't mention a topology which is used for some reasons,ipsec tunnels v.s. but only communicating (with a ping test) these two locations basically. That is, i am concerning about to do ping test from the LAN side of ADSL router connected to the ISP's ATM/MPLS backbone to the WAN interface of the other Router connected to ATM/MPLS backbone.
So what should be done differently at the dsl routers side working two sidesat ATM network, one side ATM the other MPLS or both at MPLS.
189
