Community Member
OSPF adjacency over PPPoE
How is it possible to create OSPF adjaceny over PPPoE in a case when PPPoE server assigns IP add to PPPoE client? The issue I face is that PPPoE client creates /32 route (what is normal) same as PPPoE server. Since the neighbors are on different IP subnets, OSPF does not form adjacency . Is there any way to overcome this behavior?
1 REPLY
Silver
Re: OSPF adjacency over PPPoE
A vague idea. Treat the pppoe connection as an ip unnumbered link and try seeing if the neighborship comes up. Iam assuming you have a static IP for your connection. You can add both the static IP and the remote PPPoE source (Loopback typically) in the network.
http://cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9e0.shtml
577
