OSPF areas question
Hi Guys !
Is it possible to configure the same network for the separate OSPF areas.
Example:
network 1.1.1.0 area 0.0.0.0
network 1.1.1.0 area 0.0.0.1
network 1.1.1.0 area 0.0.0.2
I have some strange flip when it was configured this way, I assume this is not supported and is wrong configuration of OSPF , am I right ?
thanx !
Purple
Re: OSPF areas question
That is not possible. If you enter the above, you will find that you will just be left with the last statement; the first two will be overwritten by the 'network 1.1.1.0 area 0.0.0.2' command.
Paresh
PS. Pls do remember to rate posts
just to clarify the meaning of the network interface in OSPF: the network statement is used to identify which interface belongs to which area. It is not used to specify the networks which should be routed by OSPF, i.e. the OSPF network statement does not have to match the interface network mask. An interface can only belong to one area in OSPF.
So if you have a router with two interfaces S0 and S1 the config can look like this:
interface Serial0
ip address 1.1.1.1 255.255.255.252
interface Serial0
ip address 1.1.1.5 255.255.255.252
router ospf 10
network 1.1.1.1 0.0.0.0 area 1
!this means Serial0 belongs to area 1
network 1.1.1.5 0.0.0.0 area 2
!this means Serial1 belongs to area 2
Be aware that both networks will be announced to both areas. So connectivity is not an issue here. make sure the respective neighbors connected to S0 and S1 are in area 1 and area 2 respectively.
Hope this helps! Please rate all posts.
Regards, Martin
97
