OSPF configuration
mailaglady2
I have two routers connected by a serial cable. I have configured ospf but it's not working.
this is how I did it/;
conf t
router ospf
network 192.1.1.0 0.0.0.255 area 0
and on the other router exactly the same but different network number but the same area, my problem here is I cannot see the networks that i am advertising on the on the router and vice versa.
please help what could be a problem here?
12 Replies 12
andrew.prince
Level 10
Level 10
You have to configure:-
1) The IP subnet you are using for the serial link.
2) The IP Subnets you are using the either router LAN connections.
3) They must be in area 0 or you have to create a virtual tunnel to area 0.
HTH>
Do I need to do all these steps or one between them.
Please show me the first one lets say my serial ip's are 165.148.120.1/30 and .2/30 for router A and B respectively.
network 165.148.120.0 0.0.0.253 area 0
Joseph W. Doherty
The two routers need to share a link with OSPF. You write you're using a "different network number" on the other router. If you want to see other routes, those interfaces need to be known to OSPF.
Assuming the shared link is 192.1.1.0/24 and the first router has another interface such as 192.1.2.0/24 and the second router 192.1.3.0/24, config might look like:
first router:
router ospf
network 192.1.2.0 0.0.0.255 area 0
second router:
router ospf
network 192.1.3.0 0.0.0.255 area 0
I have tried that but I still cant see these routes on my routing table.. when I do my "sh ip route" I can't see these routes. i can only see the directly connected ones.
post configs for review.
use mask 255.255.255.252 for the serial link, and 255.255.255.0 for the ethernet interface networks.
netwalkr1
If both serial interfaces are configure in a point-to-point (PPP/HDLC) configuration make sure you have IP connectivity. I know this is basic but, without the configs posted I'm assuming worst case scenario. Once you verified connectivity, use the network statements 192.1.1.0 0.0.0.255 area 0 if that is the IP subnet of the serial interfaces. You may also want to configure loopback interfaces for the neighbor ID.
See this link for a step-by-step walkthrough.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094057.shtml
HTH,
Shaun
zartar911
As what Shaun said, first make sure your layer 2 (port & line are up) & 3 (Ping the other IP address) are working.
After verifying that a sample OSPF configuration could be as follows:
ROUTER1
router ospf 1
network 165.148.120.0 0.0.0.252 area 0
ROUTER2
router ospf 1
One other thing to check is the ospf network types are the same.
Tim
Thanks it worked, my problem was with the serial.
I had configured like this 165.148.120.0 0.0.0.0 area 0 instead of
165.148.120.0 0.0.0.3 area 0.
Thanks good people, you have been a great help.
Your welcome! Please mark this thread as "solved" and don't forget to rate the responses.
How do I do that?
